| Home > Technical Chat > Engine rebuild spec help | ||||||
8 Posts Member #: 9201 Junior Member |
25th Nov, 2010 at 03:53:02pm
Hi guys im picking up a bare block on the weekend and want to get some options on the table for building my turbo lump.
25th Nov, 2010 at 03:56:12pm
also i forgot to mention i will probably be getting the bottom end balanced and all machining will be done by a professional i will be doing the assembly of the block. |
25th Nov, 2010 at 05:10:28pm
I'd do a bit of a search - all this has been covered many times before;
25th Nov, 2010 at 05:24:16pm
avonbar phase 2 cam
25th Nov, 2010 at 07:04:50pm
As said in the initial post i am looking for something i can use daily and also something that will be fun, power wise 100bhp - 150bhp i dont want anything thats going to be needing a rebuild every other week, the only reason for asking is that the block im getting needs a re-bore and would like some options for people who have turbo motors that run them regularly. as said the block is bare and will have all new components when finished
Edited by steve01 on 25th Nov, 2010. |
25th Nov, 2010 at 07:06:34pm
apbellamy thanks for the info im going to check out avonbar now. |
25th Nov, 2010 at 07:09:52pm
If a +0.020" rebore is enough to clean the bores up then go to that. This will leave more material in the block for future rebores should they be needed. |
25th Nov, 2010 at 07:25:26pm
Turbo Phil thanks for the advice i will probably go with your recommendation.
