| Home > Help Needed / General Tech Chat > Whats lighter | ||||||
![]() 2102 Posts Member #: 432 Post Whore Swindon |
2nd Mar, 2005 at 04:21:01pm
which of these are a better buy, carbon fibre of fiber glass |
2nd Mar, 2005 at 04:36:17pm
Carbon fibre is lighter,getting a flipfront myself soon,just cut the front off today prob have a fibreglass one thou as they come in white so wont bovver painting it as the car is white
2nd Mar, 2005 at 04:52:57pm
dans (pot_dan) will sell u his flipfront in primer with brace bars cheap Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
2nd Mar, 2005 at 05:15:49pm
but you cant easily buy carbon fiber panels...
AlexF |
2nd Mar, 2005 at 06:55:32pm
On 02/03/2005 16:36:17 Dangerous said:
Carbon fibre is lighter, Are you sure?? I've had both a Curley CF and a FG front end at the same time, and the Fibreglass one was far lighter. But, the CF one is stronger. On 13th Jul, 2012 Ben H said:
2nd Mar, 2005 at 08:21:40pm
carbon fibre panels are easy to buy....
2nd Mar, 2005 at 11:01:13pm
curley isnt true cf, its atleast the same weight as grp if not more
3rd Mar, 2005 at 12:16:11pm
If youare just talking about panels (i.e. flip-front) then the weight difference between glassfibre and carbon fibre is zero, as greypride says cf maybe heavier.
3rd Mar, 2005 at 08:34:56pm
On 02/03/2005 20:21:40 iain said:
carbon fibre panels are easy to buy.... from what ive been lead to believe, carbon is less likely to degrade over time so will last longer. we're talking years mind!! I dont know a single manufactuer that use real CF and no glass as a base... carbon fibre is much stronger so you can make the front thinner and hence lighter... sadly most dont, for example Curley is GF with a CF top to it for better strength! Alex AlexF |
3rd Mar, 2005 at 10:23:53pm
think of the saftey aspect as well
4th Mar, 2005 at 07:42:18am
you thinking about a flip front and safety?
AlexF |
4th Mar, 2005 at 11:30:31am
well im goin with the theory that shoud i crash im fcuked anyway, so ill just go with whats cheaper out of the 2 as it seems to be about 50/50 with the coments.
4th Mar, 2005 at 03:37:27pm
Life is one big race!
4th Mar, 2005 at 04:02:02pm
hmmmm i might change race to risk.
5th Mar, 2005 at 11:06:25am
roll cages kill if you dont wear a helmet...
AlexF |
5th Mar, 2005 at 02:13:21pm
new one on me to alex....but. ..........................
6th Mar, 2005 at 01:16:12pm
Evidence...
AlexF |
6th Mar, 2005 at 02:41:22pm
point taken alex.
6th Mar, 2005 at 03:16:26pm
you want to use rool cage padding...
AlexF |
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
12th Mar, 2005 at 05:23:03pm
Like for like carbon fibre is lighter than fibre glass, end of story.
Edited by Mirage on 12th Mar, 2005. |
12th Mar, 2005 at 07:10:21pm
Mirage just about covered it all, comparing the two is not that simple. Most of the weight is resin not cloth. Even with pre-preg it is possible to end up with heavy pieces. Pros use either autoclaves or vacuum bags to cure the laminate. The idea is to "suck" all excess resin from the laminate and press the layers tightly to each other to prevent delamination, bubbles and stuff from the laminate. These weaken the end result. Boy racer carbon fibre stuff has nothing to do with pro stuff. If you want cheap CF you can buy fake adhesive sheets...
12th Mar, 2005 at 11:01:29pm
My Curley Fibre glass front end is lighter than the CF one. PERIOD!
