Home > Help Needed / General Tech Chat > refacing clutch backplate
turbominij
Member #: 2104
Essex - UK
anyone know where to get a clutch backplate refaced or if its even possible.
im in essex so somewhere local would be ideal
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
Yes it is possible, any decent machine shop should be able to do it, make sure they remove the same amount of material from the lugs as well.
turbominij
Member #: 2104
Essex - UK
ok thanks for that tom.
in that case anyone no any decent machine shops around essex/colchester?
