Page: |
Home > General Chat > SC 5 Port EFI testing...the results are in....interesting! | |||||||
30th Nov, 2010 at 12:06:18am
There are many ways to get EFI wrong on the 5-port engine and few to get it right. And if you get it wrong, you will be worse off than with a carb and potentially much worse. The only way to know if you're at least as good is to measure the AFR on inner and outer cylinders.
112 Posts Member #: 7030 Advanced Member Bucks |
30th Nov, 2010 at 10:30:13am
On 29th Nov, 2010 gr4h4m said:
I think John is getting un-fair treatment. I think John's been asked some straightforward questions and responded in a way that essentially boils down to bluff, bravado and diversion to take attention away from those questions. It's always been interesting to read here on these forums about new developments that SC have undertaken and I've been a fan of what SC does. And John's always usually received keen interest from the knowledgeable people here. I hope John will set the record straight eventually. :) |
30th Nov, 2010 at 06:49:18pm
Interesting exhaust manifold there John,
196 Posts Member #: 2301 Advanced Member Blackpool , Lancashire |
30th Nov, 2010 at 07:25:44pm
Lovely picture Sam.... http://s256.photobucket.com/albums/hh167/boz-reb-2303/
388 Posts Member #: 442 Senior Member Manchester |
30th Nov, 2010 at 09:10:15pm
Id be interested to see what AFR a normal SPI achieves as a comparision to this kit.
6274 Posts Member #: 509 Post Whore Isle of Man |
30th Nov, 2010 at 10:12:53pm
i believe the typhoon ecu covers the ignition side of things aswell mat "Turbo's make torque, and torque makes fun"
9313 Posts Member #: 59 First mini turbo to get in the 12's & site perv Herefordshire |
1st Dec, 2010 at 08:36:22pm
This thread is a perfect example of how poor TM has become as of late.
1st Dec, 2010 at 09:05:49pm
On 1st Dec, 2010 Nic said:
This thread is a perfect example of how poor TM has become as of late. I disagree (and you will probably think this confirms your opinion). Unless you think evading valid technical questions is an acceptable way of marketing a new product. Even a knowledgeable and reputable source should not be above that. And let it be clear that I have nothing to gain or lose whether this product does well or not. My only concern is that people are correctly informed if they want to use it in a manner that is different that the presented application. And as opposed to what John claims, it may not be appropriate for all applications mentioned in this thread especially in view of some other information on this product that have not been mentioned here. Jean |
Site Admin 15300 Posts Member #: 337 Fearless Tom Fenton, Avon Park 2007 & 2008 class D winner & TM legend. |
1st Dec, 2010 at 09:19:30pm
I have to say I do not understand why if SC have the AFR data, they do not make the results known. Surely this will answer the debate one way or another?
Forum Mod 10979 Posts Member #: 17 ***16*** SouthPark, Colorado |
1st Dec, 2010 at 09:33:07pm
My opinion of this, and perhaps I'm missing something (so everyone correct me if I'm wrong) is that John never said his system gives perfect fuel mixture - it does clearly suggest that the mixture is equal to that of a carb (a weber).
Edited by TurboDave16V on 1st Dec, 2010. On 17th Nov, 2014 Tom Fenton said:
3074 Posts Member #: 1348 Post Whore wakefield West Yorks |
1st Dec, 2010 at 09:39:17pm
I think whats you've said dave is right on the money.
1st Dec, 2010 at 09:58:27pm
Dave,
1st Dec, 2010 at 10:10:54pm
I can "take a step back", I have avoided posting since it got rather inflamed, but.......
4890 Posts Member #: 1775 Post Whore Chester |
1st Dec, 2010 at 10:13:25pm
Even with all this talk about the perfect setup John would still get my money. If I had any left. I run a supercharger and I don't care the TB is on the wrong side.
1st Dec, 2010 at 10:17:12pm
On 1st Dec, 2010 gr4h4m said:
Even with all this talk about the perfect setup John would still get my money. If I had any left. And as mentioned before, for a suck through supercharger setup it would be fine. The issue is not there. Jean |
6549 Posts Member #: 1149 #1 Basshunter Fan Force Racing ICT Dept Manager Miglia Turbo Am frum Yokshyer tha noes! |
1st Dec, 2010 at 11:12:57pm
Here here
On 1st Dec, 2010 TurboDave said:
My opinion of this, and perhaps I'm missing something (so everyone correct me if I'm wrong) is that John never said his system gives perfect fuel mixture - it does clearly suggest that the mixture is equal to that of a carb (a weber). It makes the same power as a weber - suggesting that it is not worse for fuel distribution. It does improve drivability (probably partly due to ignition control) - mostly from being able to get better fuelling at all load sites. I know for a FACT that the guy on here with the highest HP A-series, and the guy on here with the quickest 5-port over the 1/4 have never, ever, even once loked at their fuel distribution, to see how pooly balanced their mixture is. But their engines work. And they work well, achieving their personal goals. To poo-poo what John is offering as a 'bolt-on' kit, that will perform slightly better than an SU ever will (within the limitations of available injector flow for the desire HP) is to tell Nic and Matt that their engines are a pile of shit as well. So why not start a new post, telling them this. Or maybe tell them to their face. I know there is a lot of work, and hence a lot of pride in getting to the magical 100% of optimum, but how about this for a scenario: If you one 'team' can get to 90% of optimum, for a lot less hassle or a lot shorter lead time; and be competing, or even winning races whilst the '100% target or nothing team' is still working at achieving their goal; which 'team' are most folks going to think has the 'better result'? Or to put it another way, who has any right to say that their approach is better than anyone else's? I hope I haven't upset anyone here, but that's how I feel - and the fact that someone develops something that should be worthy of a 'thumbs up' instead gets flamed, is very disapointing. Unless some attitudes start changing, this post will be locked and disapear into the depths of the forums. I suggest everyone take a step back, and look at what you've posted, and see it from the other persons perspective before posting anything else. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
11046 Posts Member #: 965 Post Whore Preston On The Brook |
2nd Dec, 2010 at 12:00:50am
The only thing I will add to this debate is that, with my 1400 Spi using the factory injection manifold (apparently shit), factory ECU, and 10.5:1 compression, giving at that time 90hp, ALL exhaust valves were the same colour.
2nd Dec, 2010 at 12:31:08am
On 2nd Dec, 2010 Sprocket said:
The only thing I will add to this debate is that, with my 1400 Spi using the factory injection manifold (apparently shit), factory ECU, and 10.5:1 compression, giving at that time 90hp, ALL exhaust valves were the same colour. So what you might exclaim. What you have to consider is what this is telling you. Its the same as reading spark plugs, and that, is the oldest way to really understand what is going on inside the combustion chamber, outside of all this funky electronic data logging. The easiest way to compare the cylinders, is to do a plug run. Run the engine up to the load point you wish to look at, hold it there, then imediately shut the engine off, pull the plugs and read them. what is to say John has not done this? I also have not heard anything about fuel film on the 'wet' manifolds. surely even with a pulsing fuel injection, this fuel film compensates some what by the time the charge reaches the cylinder. Im am far from saying this cures the charge robbing. Port injection does not have enough wet area to compenaste anywhere near enough. I may be way off the mark, but in all these conversations I see little consideration for the huge surface areas of a wet manifold, and, like Dave has said, if its 90% there, is not damaging the engine, and giving the goods, where is the problem? maybe run all cylinders richer to bring the avarage AFR down. Lets not forget that most production injection systems are tuned to an AFR of around 13.2:1 rich, so if the rich cylinders are 12.5:1 with the lean cylinders 13.2:1, all cylinders are within the AFR range for best torque. (As an example). I'm sure Paul will have hard data that would confirm this some what, however, the numbers in my example might be way off the mark. If John has read the plugs or lifted the head or whatever else to validate the AFR then it hasn't been presented even in qualitative way. What has been offered is EGT which has been proven with measurements from two independent sources to be irrelevant to establish AFR and fuel distribution. So no one can say if he's 90% there (whatever that means) or 50% or 99%. From measurements with data available on this forum, it is possible to have an engine that will run quite nicely at an AFR mismatch much worse than what you mention above. So is it so strange to ask for relevant data from someone who should be able to provide it easily? And is it a good thing for 2 members of this forum (Paul and Rod) who have done a lot of work and presented there results here to basically be called shit stirrers because the point out the wrong conclusion and ask for more relevant data? (Unless I"m the one being call this and in this case I don't care because I mentioned my intentions already) And there's also the issue that no matter how close it is in the setup presented here (which seems to be better than a carb and perfectly adequate as a more practical setup), there is nothing showing that it would still be acceptable in a highly boosted setup. Again, there's been arguments presented here against that being and nothing has been presented to counter that and there is no running example. And a lot of people don't seem to understand that the fact that it is working as a carb replacement in an NA situation doesn't mean it will work in another configuration. The explanations for this can probably be found on this forum in the numerous discussions on the subject. And by the way, the wall wetting will not improve fuel distribution but make it worse. This can again be found on this forum. So call me a shit stirrer but at least present me with facts and data that make sense especially if you want to sell something (and as far as I know there is only one on this thread). And I'm not saying the product presented is not good but the data about it is not complete and you can't make extrapolation from it. And please tell me you don't advocate using a pure Alpha-N setup for a blowthrough turbo setup. Jean |
2nd Dec, 2010 at 12:55:24am
On 2nd Dec, 2010 jbelanger said:
And by the way, the wall wetting will not improve fuel distribution but make it worse. This can again be found on this forum. I was merely suggesting that a wet manifold, (for want of a better expression) works in a similar manor to a capacitor, drying out when the injector is in an off period, recharging when the injector is in an on period. As such the injector needs to add a little more fuel to replenish the wall film that was lost during the off period. I thought I made it clear in my post that I was in no way suggesting that it fixed the charge robbing issues. The theory that anything other than port injection and siamese code is worse than a carb as a result of the pulsed nature of the injector compared to a contiuous flow from a carb, I find hard to justify, but then, I have not done any testing to confirm my thoughts one way or the other. The theory about the carb being a contiuous flow, in itself could be debated, considering the pulsing nature of the induction on a 4 cylinder engine. Again, I am not making out that wet manifold injection systems are any better than a carb, but would consider them equal, for now at least. I'll have an engine on the dyno soon enough to test out the factory SPi manifold, with some hard data, AFR's and EGT's. As far as I am aware, no one on this forum or any other, has this data from a factory SPi system, so how can anyone dismiss it as (again for want of a better expression) rubbish compared to a carb? On 26th Oct, 2004 TurboDave16v said:
2nd Dec, 2010 at 01:24:54am
I'm not sure anyone has said that an SPi setup will automatically be worse than a carb. It can be as "good" as a carb but you have to do it correctly. And you have to measure it correctly (as you intend to).
2nd Dec, 2010 at 09:00:12am
I think that it is time to wrap this thread up.
2nd Dec, 2010 at 10:38:49am
before this wraps up i thought I'd post this, I'll also post it in Pauls runner thread,
3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
2nd Dec, 2010 at 11:35:21am
you lot need to jam your hype.
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
5329 Posts Member #: 140 Proven 200+bhp & Avon Park 05,06,07 Class D 3rd place |
2nd Dec, 2010 at 01:25:32pm
Yes have to agree with a few fellas, can't believe all this, what happend to TM being a friendly place! Best 1/4 mile 13.2 seconds @116 mph
1425 Posts Member #: 690 Post Whore Norfolk |
2nd Dec, 2010 at 01:33:15pm
I've asked for the thread to be locked and removed. I'll also be leaving TM as this wasn't the forum I joined 5 or more years ago. Good luck to you all and I look forward to seeing the familiar faces at the shows next year
If Carling made Mini engines
Page: |
