Home > Help Needed / General Tech Chat > Is my box ok(PICS)
Dangerous
Member #: 417
Been out the garage today busy with the grinder so front of complete,and box half in.
welder playing up wire keeps stopping mind u its a bit rusty,would a bit of fairy liquid help??
To be continued *happy*
evolotion
Member #: 83
Glasgow, Scotland
i replaced the wire guide in my welder with a tefon carke one, as mine kept sticking too. was easy enough to do (i have an el cheapo SIP welder) wuitha few modifications.
Denis O'Brien.
box looks fine *smiley*
Nick
Member #: 154
Midlands
you've got a big brown stain on your box dude!
Dangerous
Member #: 417
Kinky...........Where does the r/h tiebar mount go?????
the what? that goes on the subby...
ps, chuck the wire and get fresh stuff, spray anti splatter into the nozzle too and you should find it easier.
get the EARTH close to the working area and make sure its a GOOD clean earth
find this a lot especially if the mini is genrally rust all over
Dangerous
Member #: 417
[quote=iain,02/03/2005 20:59:05]
Just thought I read somewhere about making sure you do the bracket for the extra top mount.
Oh had a slight accident too.......when cutting of for flipfront watch out for the earth wires(about 8) on the drivers side....
SumpNut
Member #: 28
If you want to run an extra engine steady you will need to weld on a braket onto the firelwall/bulkhead as the mounting (left hand drive master and clutch cylinder holes) will have been half removed by the box.
I personally have never run a 2nd top engine steady, i have 2 on the box and one on the driver side of the engine - i just dont see the need.
Most men have a brown stain in their box. Women on the other hand are pinkish.
n.g.l.
Member #: 181
Chard, Somerset
Box looks O.K. but the welds could be better considering that the area thats been cut out is a major structural part of the shell. If I when you I'd renew the bowden cable liner in your welder. It's the part that looks like a bicycle brake cable running from the welder to the torch. These should be replaced periodically because rust can build up in the liner which is transfered to the wire causing it to start and stop when your trying to weld creating a poor weld.
I didn't bother welding a bracket for the engine steady, i just made a new one like this. *smiley*
Dangerous
Member #: 417
Thanks for replies,got all the bits to re-furb the welder today think I will leave the bracket as I can always bolt something through afterwards as I have no carpets heater etc(saving wieght)
