| Home > Technical Chat > Knock Sensor Connected to LED | ||||||
![]() 334 Posts Member #: 7169 Gobshite that posts wank videos. Somerset, UK |
28th Nov, 2010 at 12:34:33pm
Was thinking about connecting up a Knock Sensor to an LED on the Dash would be very helpful for mapping or just as a precaution.
Gaball said:
Motorsport Engineering Student Project Car 1293 Turbo Mini (on a student budget) On 7th Oct, 2010 apbellamy said:
Carbon but plug? |
28th Nov, 2010 at 12:39:50pm
As I believe Dennis said, he found his ears to be a much better knock sensing device than any electronic device.
28th Nov, 2010 at 12:45:49pm
The knock sensor alone is not enough, if you mean just the bit that screws to the block.
28th Nov, 2010 at 12:53:52pm
Carbon but plug? |
28th Nov, 2010 at 01:01:24pm
you can make a home brew knock/pink detector. all you need is some copper pipe, rubber hose and some ear protectors Edited by apbellamy on 28th Nov, 2010. On 11th Feb, 2015 robert said:
28th Nov, 2010 at 01:02:28pm
Personally, as Tom says (quoting Denis), you can hear it if you know what you're listening too. I know it well from my days with high powered Imp engines.
28th Nov, 2010 at 01:05:21pm
Rod S correct me if I am wrong but I was lead to believe that the signal from the knock sensor all be it a frequency produces a 5v amplitude which would be enough to trigger a transistor or is this after the module? Gaball said:
Carbon but plug? |
28th Nov, 2010 at 01:20:39pm
After the module, unless there are some fancy sensors out there with the electronics built in.
28th Nov, 2010 at 01:25:59pm
On 28th Nov, 2010 Rod S said:
After the module, unless there are some fancy sensors out there with the electronics built in. Which make of sensor are you thinking of ??? Bosch if any Gaball said:
Carbon but plug? |
28th Nov, 2010 at 01:37:34pm
Bosch, but from what vehicle - the sensors are mated to a module or connect direct to the vehicle's ECU.
28th Nov, 2010 at 01:42:25pm
right now i don't really know because it was a plan on paper i was checking with the electronic smarts on here that i had my facts right.
Carbon but plug? |
28th Nov, 2010 at 02:13:00pm
I used to use a mechanics stethoscope extended into the cab. I don't find it much use as it's not very clear over the sc box. Ive just fitted a egt gauge though to get around the problem.
28th Nov, 2010 at 07:25:20pm
there wre two types of knock sensors, resonant(like older toyota), and non-resonant (i.e. bosch).
28th Nov, 2010 at 08:35:34pm
so in short its rediculously complicated it would basicly meen making a new knock sensor, finding the frequency the a series knocks at and then program it then connect an LED to it :/
On 28th Nov, 2010 evolotion said:
there wre two types of knock sensors, resonant(like older toyota), and non-resonant (i.e. bosch). the frequency of knock is engine dependant, main variables are cylinder bore and block material, but there are many other things to consider. Put simply any knock detectign device needs "tuned" to a particular engine. the resonant type of sensor has a mass and a spring, at the tuned knock frequency the mass resonates, this gives an output which can be vuewed with a simple transistor/LED. This style of sensor has never been fitted to an a-series, so you cant get one. a non resonant sensor requires electronics with a bandpass filter at the tuned frequency, and a noise filter, that can then display an output. trouble is both these setups become useless on a noisy engine (and the a-series is a noisy engine!) above 4krpm or so. and where would damage most likely occur? above this threshold :) if your good with mathlab i had some success runing an FFT on a bosch sensor signal then processing itto output above a threshold, should only require a laptop to give you a proof of concept, but by the time you perfect it you will know how to listen for it :) Gaball said:
Carbon but plug? |
28th Nov, 2010 at 09:19:41pm
there's lots of good reading on the internet on the subject, i think auto-speed maybe even had some simple demo circuits to filter the noise. if your a-series is all-helical gear boxed and belt drive on the cam, you stand a decent chance of getting it to work. turbo 16v k-series 11.9@118.9 :)
28th Nov, 2010 at 09:22:40pm
Thats a no for me then haha.
there's lots of good reading on the internet on the subject, i think auto-speed maybe even had some simple demo circuits to filter the noise. if your a-series is all-helical gear boxed and belt drive on the cam, you stand a decent chance of getting it to work. Gaball said:
Carbon but plug? |
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
29th Nov, 2010 at 05:09:15pm
Type KnockSense into your browser. Imported mine from the US when I was building up my Megasquirt.
Edited by turbominivanman on 29th Nov, 2010. Minivanless, but reluctantly happy living with the decision. There'll be another one day.
29th Nov, 2010 at 05:56:21pm
Robert uses some sort knock light can't remember the brand though! |
520 Posts Member #: 2093 Post Whore Grenoble, France |
5th Jan, 2011 at 11:31:11pm
All modern Bosch knock sensors are the same. 15khz bandwidth. They only differ by the connector and wire length.
std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
