Home > For Sale > 8mm 5251 H22 Aluminium & other offcuts
Jason G
Member #: 1459
En-suite user
Braintree, Essex
As title, wire mesh. Approx 20 wires per inch. Overall size 1000mm x 1000mm. Not sure if its any use to anyone. £10.00
Also, offcuts of 8mm Aluminium. Not sure if its 5083 or 5251. Come as approx 350mm discs. Will get prices & grade in a week when back at work.
Edited by Jason G on 9th Dec, 2010.
On 19th Jan, 2010 wil_h said:
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Inconel gone, will update about ally later. Will see what other metal is kicking about.
how much you think it would cost to post the mesh? cheers
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Gave it to mini13. Earlier we were trying to figure out what anyone could use it for.
Throw him some beer tokens, I'm sure he will cut a chunk off for you.
nahh it doesnt matter then, it would probably have just sit here untill i find a place for it :)
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Only thought I had was using it for n/a lumps running a webber, stopping it sucking a filter down its trumpet.
was thinking of de-grilling the volvo, thats what i had in mind
Have a measure up, I'll trim a bit off for you.
ok buddy will doo
jlay
Member #: 1742
essex
i might be interesten in some aluminium when you get the info cheers
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
Jason G
Member #: 1459
En-suite user
Braintree, Essex
No probs. Where abouts in Essex are you?
jlay
Member #: 1742
essex
Hiya im just outside southend-on-sea
Jason G
Member #: 1459
En-suite user
Braintree, Essex
PM sent
