| Home > General Chat > Electronic scales of temp senders | |||||||
![]() 453 Posts Member #: 6449 Senior Member Brisbane, Australia |
1st Dec, 2010 at 07:24:52am
Now this question isnt turbo mini related but im hoping someone will be able to help me out with temperature sensors.
In boost we trust |
1st Dec, 2010 at 09:36:49am
So i did a bit more testing of the 2 types of sensors i have and got:
In boost we trust |
1st Dec, 2010 at 09:56:28am
well, if both are working properly, not really
1st Dec, 2010 at 10:03:11am
Why not stick with the reliable mechanical water pump ?
1st Dec, 2010 at 10:08:36am
Without knowing exact deatils of the sensors you have, what I'm about to say is a bit of a generalisation.....
1st Dec, 2010 at 10:26:00am
Thanks Rod, thats pretty much the answer i was looking for. Except a hell of a lot more in depth than i know. The sensors didnt come with part numbers or anything, so i guess ill be getting some decent ones. Sensor 1 was out from the electric water pump and sensor 2 from the digidash.
In boost we trust |
1st Dec, 2010 at 12:04:55pm
Cant the ecu put an output to the pump controller ?
2nd Dec, 2010 at 12:31:38am
On 1st Dec, 2010 stevieturbo said:
Cant the ecu put an output to the pump controller ? And wont the dash also interface with the ecu, to offer any information it has ? Would negate the need for multiple anything. Ive looked into what you say, interfacing everything together instead of running separate systems. But, its an aussie ecu, an english digidash and a no idea where from water pump. So no one can confirm that its useable as theyve never done it. Ill probably end up running them all together off one sensor and see how it ends up, or pay someone huge amounts of money to fix it. In boost we trust |
2nd Dec, 2010 at 02:21:03pm
The crappy DC pumps are australian.
