| Home > Technical Chat > battery | |||||||
3rd Mar, 2005 at 05:04:31pm
if i run a brand new big battery (astra diesel) on my 998 it coughs splutters hardly starts (just spins over) and runs like a bag of spanners Edited by wolfie on 3rd Mar, 2005. Crystal Sound Audio said:
421 Posts Member #: 245 Senior Member |
3rd Mar, 2005 at 08:04:22pm
did you fit the astra diesel engine as well.lol |
612 Posts Member #: 414 Post Whore Dalbeattie Scotland |
3rd Mar, 2005 at 10:50:36pm
I recon that there is somthing amiss here a battery is a battery if it is a higher output battery and it is slower to start then the battery must be duff check the voltage with a volt meter while cranking the starter you should still have over 12.5 volts. |
4th Mar, 2005 at 12:44:41pm
volts are not a problem its spins very quickly Crystal Sound Audio said:
4th Mar, 2005 at 12:45:29pm
would it be the points gap? to small/large for a higher power battery? Crystal Sound Audio said:
4th Mar, 2005 at 02:24:42pm
although it is higher power as it is bigger and meant for a diesel engine, the power that is different is the cold cranking power and the reserve capacity. The cold cranking is to do with how fast it can spin the engine over in harsh conditions, the reserve capacity is how long it can last if your alternator craps out on you.
7th Mar, 2005 at 08:34:46am
Good answer Tom. It's worth nothing that the dizzy module on the Metro dizzys are very voltage sensitive. i.e. a low supply could cause a missfire.
