Home > Help Needed / General Tech Chat > Boost leak!
insamoufonyx
Member #: 7071
Nailsea, Near Bristol
Hi all,
Ive got a boost leak on my metro turbo engine,
Any comman places for this? its really high pitched squeele so thinking its gota be a really small leak.
So far checked:
manifold to head
manifold to carb
carb to plenum chamber
actuator
vac lines.
Any other comman ones? its driving me crazy.
is the std dump valve in the plenum blocked off?
soapy water in a spray bottle and a squirt up the road?
insamoufonyx
Member #: 7071
yeh std dump valve has been welded up, suppose i can have a go with the soapy water but would have thought the heat would dry it up
evolotion
Member #: 83
Glasgow, Scotland
turbo shagged and blades hitting the housing?
Denis O'Brien.
insamoufonyx
Member #: 7071
nope, had a turbo re-build about 600miles ago and would have thought would make a bit more noise than that. it is defintly a air leak. it also boosts up fine but when it hits 5ish psi you can really hear it
Boost hoses?
Johnny
Member #: 6926
Accrington
change the hoses like lizzard says, might be a pin hole/rip on one? or just take them all off and put back on. (sometimes this works)
Star Mag
Member #: 375
Leicestershire
Block off the compressor housing with a cap, then connect the airline to the boost circuit and fill it up, listen for the leak. I have a fitting in the plenum!
And when did the noise start ?
Who rebuilt it ?
mcalvert39
Member #: 442
Manchester
Have you rebuilt the carb? Spindle seals?
insamoufonyx
Member #: 7071
Right, star mag, just tried your idea and it seams to have worked, was leaking between the body of the plenum and the hose takeoff, sealed it just waiting for it to dry now, hopefully thats it.
Ah, a sneaky leak!
fingers crossed,
