Home > Help Needed / General Tech Chat > Up sh$t creek with or without a paddle??
Kean
Member #: 341
aka T2clubby
South Staffs
Is anybody running a paddle clutch plate...
Im thinking of using one in my car but I'd apreciate your views first.
Hopefully my car will be pushing around 150-160bhp, however it wil be a road car... not my everyday car but will still do a fair few miles going to shows etc..
Is the paddle a good idea? or will it piss me off royally
cheers
minimark
Member #: 19
newcastle
paddle and grey , hard on your leg ,but ok ....
sauber 200
Member #: 245
used to use a paddle,pain in the arse now use grey/rally plate.
Dave swears by his organic plate and puts it down to his good 1/4times without an lsd as you can feed it in.
Ill try one of these plates first i reckon, not the end of the world to change it.
T3Tone
Member #: 252
Sunny suffolk
Drove a mini with a paddle plate and found it like a switch, could'nt feed it in smoothly, not nice for road use. Im using an AP rally plate/grey diaphram with no probs.
-MINI CLUBMAN 1380 TURBO-
Grey diaphragm with rally/race plate will be fine for most applications. Daves engine has over 150ft/lb of torque and he has no problems with this setup. It's also fine for road use.
Phil. *smiley*
Kean
Member #: 341
aka T2clubby
South Staffs
Thanks for the replies lads...
Rally race plate it is then *happy*
yeah isnt that the organic one though phil? sure he said it was...
Well I've been using the AP rally plate for years. I've never had big problems with it but I can still cook it if I'm not careful, that's with slicks of course. I reckon uit'd be fine on road tyres.
Ive got a sintered paddle clutch for this year though as I lost a few good runs last year with the AP slipping after a few to many enmergency starts .
Wil
Have you set up the clutch correctly with a flat diaphragm? I'm sure most turbos could get away with an orange plate if done correctly. A decent 1400/286 engine may use a blue one...
I guess it's down to pub-points :)
The stiffer the spring, obviously the more horsepower. ( not aimed at you Wil)
Disk full (/tmp/#sql_c9d4b_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
