| Home > Help Needed / General Tech Chat > Gathering parts, again. | |||||||
275 Posts Member #: 4600 Senior Member Melton Mowbray, near Leicester |
3rd Dec, 2010 at 01:37:24pm
My project has suddenly jumped leaps and bounds with deciding to buy a 1979 and use that shell, so it'll be on the road a lot sooner than planned.
Edited by analogue_radio on 3rd Dec, 2010. |
3rd Dec, 2010 at 01:40:38pm
Put an MG metro (non-turbo) cam in. That'll be exactly the same as an engine I built and it was great. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
116 Posts Member #: 8367 Advanced Member bucks |
3rd Dec, 2010 at 01:40:52pm
fuel pump, fuel regulator, fuel filter? |
3rd Dec, 2010 at 01:41:45pm
Ah yeah forgot about that, I've got an MPI tank under my workbench! Which I was told does something that I needed Edited by analogue_radio on 3rd Dec, 2010. |
3rd Dec, 2010 at 01:59:24pm
you need a turbo distributor for the ignition timing OR megajolt, or something similar.
![]() 489 Posts Member #: 9159 Senior Member Devon |
3rd Dec, 2010 at 02:31:40pm
is the only thing special about spi/mpi tanks is that they have an intergrated pump and a fuel return.. so just plug n play?? |
3rd Dec, 2010 at 02:39:36pm
I don't think the SPi tank will flow enough fuel for a turbo setup. MPi flow more. The pumps are interchangable, but there are loads of fuel injection pumps designed to sit in the tank that will fit. On 11th Feb, 2015 robert said:
3rd Dec, 2010 at 02:50:37pm
Megajolt could cost £150-200?
3rd Dec, 2010 at 02:51:10pm
Oh and regarding the gasket for the head, will a standard 998 gasket do? |
3rd Dec, 2010 at 04:52:13pm
SPi tank will work fine up to about 10 psi boost pressure.
3rd Dec, 2010 at 05:00:06pm
That'll do me then, for now anyway |
3rd Dec, 2010 at 05:01:49pm
if you decide you need more boost you can just change the fuel pump, somthing like a fiesta one will fit. On 28th Aug, 2011 Kean said:
3rd Dec, 2010 at 05:07:00pm
What does that tank cover? regulator and pump?
3rd Dec, 2010 at 05:14:00pm
theres jsut a pump in the tank, you'll need to put the reg under the bonnet. On 28th Aug, 2011 Kean said:
3rd Dec, 2010 at 05:41:13pm
Right, got it :)
4th Dec, 2010 at 05:16:27pm
. Edited by analogue_radio on 4th Dec, 2010. |
4th Dec, 2010 at 06:02:09pm
Just get a metro turbo regulator. It needs to be rising rate, so it can supply fuel at boost pressure plus 3.5psi On 11th Feb, 2015 robert said:
![]() 257 Posts Member #: 7048 Senior Member Bridgend |
9th Dec, 2010 at 07:18:12pm
Have you got turbo oil feed and return lines? Turbo parts collector at the moment, almost ready. |
