| Home > Help Needed / General Tech Chat > alarm wiring | |||||||
109 Posts Member #: 8630 Advanced Member |
4th Dec, 2010 at 06:16:04pm
trying to fit a alarm to my Mayfair today and got the alarm to work but the immobiliser feature on it seems to be wired wrong. when i start the car the starter motor just keeps turning how would i wire this up so that it would work
4th Dec, 2010 at 08:50:34pm
heres a better pic i just need a hand on why does my starter motor keep turning when i start the engine
4th Dec, 2010 at 10:01:03pm
is the relay a NC or NO? (normally closed, normally open)??? Also could the starter be getting stuck? and by relay im assuming the "starter killer" is a relay?
Edited by Johnny on 4th Dec, 2010. |
4th Dec, 2010 at 10:29:07pm
im not too sure myself but heres a pic of the relay
4th Dec, 2010 at 11:24:32pm
yes thats the problem, the 87a needs to goto the solenoid... not direct on the starter... wouldnt be surprised if you havent fried your wiring? i think it should goto the little spade connector on the solenoid which should also be red and white... your supposed to cut the red and white wire and in effect put the 2 connectors on the relay in between Edited by Johnny on 4th Dec, 2010. |
4th Dec, 2010 at 11:31:58pm
i dont fully understand about cutting the red and white wire at the ignition. so i cut the red and white wire and connect that to the green wire going to connection 30. and then the 87A goes straight to the spade connector on the solenoid is that right |
5th Dec, 2010 at 02:01:24pm
sorry, i cant help i cant think without seeing what you have done.
Edited by Johnny on 5th Dec, 2010. |
5th Dec, 2010 at 05:43:49pm
cheers johnny all sorted now thanks |
