| Home > Help Needed / General Tech Chat > OT/non mini: HID bulb replacement | |||||||
5th Dec, 2010 at 09:47:17pm
I hope it's OK to ask this here but yous guys know these sort of things. My daily has blown a bulb and it's a HID variety. The bulbs are pretty feeble compared to the HIDs on my old daily. Just to make it clear I'm not a chav but are the 4300K/8000k/10000K bulbs interchangeable? Apart from general access issues are there any additional problems with changing this bulb type compared to halogen?
On 7th Nov, 2008 Nic said:
5th Dec, 2010 at 10:54:20pm
There are different kinds of HID but so long as the firment is the same it's just like swapping a halogen, however before you do (assuming one isn't working) swap the bulb over to the other side, as the ballasts often fail! turbo 16v k-series 11.9@118.9 :)
6th Dec, 2010 at 10:11:53am
Excellent Evo thanks. I will check the bulb type tonight, I wonder if a ballast is covered under warranty On 7th Nov, 2008 Nic said:
![]() 825 Posts Member #: 2208 Post Whore Essex |
6th Dec, 2010 at 03:40:06pm
4300K/8000k/10000K bulbs give off different coulor, do the pair if your not sure other wise you will have odd lights |
204 Posts Member #: 5022 Senior Member Oxford, Kings Lynn, Pod, Pub. |
6th Dec, 2010 at 03:47:29pm
Also Anything above 6000K will be far too blue and will attract the boys in blue. Also from memory 5000K gives the most light, with 6000K being with a hint of blue. Even with replacing bulbs of the same K value and having two of differing ages of bulbs can make the older look more blue
Got A GTM With A Honda In the Back, and huge Nitrous bottle where the passenger seat should be when racing!
On 19th Oct, 2009 Nic said:
Ill donate to the cause if you can make it do wheelies!! |
6th Dec, 2010 at 04:35:49pm
Thanks guys, I will replace in pairs. I liked the old daily drives 8000ks and I think mine are currently 4300ks. I know some Mercs/Landrovers have the 10000ks but not sure of legalities of fitting these to the Renault (although I think the problem is fitting HID units to cars with halogens as stock). I won't be doing anything until the snow clears though On 7th Nov, 2008 Nic said:
