| Home > Help Needed / General Tech Chat > Transit 2.5Di help | |||||||
6th Dec, 2010 at 10:18:21pm
Got this message in an email from my father. Can someone shed some light on this? I can't recall the DI engine - it's 10 years since I last did any work on one - hopefully one of you will have a few pointers.
6th Dec, 2010 at 10:44:48pm
i would agree with an air leak, the initial start is the residual diesel in the pump, after that it draws air. bastard to try and trace though :( turbo 16v k-series 11.9@118.9 :)
6th Dec, 2010 at 10:51:04pm
i had exactly this dave, if you take the fuel filter off, there should be a black rubber ring insert about the diameter of 10p piece that should be clipped into the top centre
7th Dec, 2010 at 12:58:09pm
Joe - so I assume you are saying that it might just be worth going and replacing this seal regardless?
7th Dec, 2010 at 05:49:49pm
how old is the deisel, and what is the ambient temperatures where your dad lives, over night? could it be waxing? On 26th Oct, 2004 TurboDave16v said:
7th Dec, 2010 at 06:11:52pm
Had the same issue and could never find the air leak. First question, has it a Lucas CAV or Bosch fuel pump?
On 6th Dec, 2010 TurboDave said:
Got this message in an email from my father. Can someone shed some light on this? I can't recall the DI engine - it's 10 years since I last did any work on one - hopefully one of you will have a few pointers. "I have a problem with my Transit . She starts readily as long as I "catch" her with the first turn of the key after using the cylinder heaters. However if she fails to start immediately then I can grind the starter moter for ages with no sign of firing. I have discovered that every time i get this problem that the diesel oil filter/resevoir is not full to the top. By topping it up with a couple of spoonsful of Derv and bleeding the injectors she will then start. I think that there is an air leak somewhere. I have tightened all the unions. Do you have any suggestions?" Edited by Jason G on 7th Dec, 2010. On 19th Jan, 2010 wil_h said:
7th Dec, 2010 at 08:49:42pm
He uses this once every two / three days. Diesel is prob less than a month old I reckon. He is in Manchester.
7th Dec, 2010 at 09:55:12pm
dave as above but ..... dont disregard the slippage hoses which are connected to each injector and to the next one and the blanking one on the end these perrish and or split and cause this classic problem you describe. Edited by BENROSS on 7th Dec, 2010.
7th Dec, 2010 at 10:33:08pm
On 7th Dec, 2010 TurboDave said:
He uses this once every two / three days. Diesel is prob less than a month old I reckon. He is in Manchester. I'll find out if it's the bosch pump or Lucas pump. If the deisel is likely to be nearly a month old, it was not as freakishly cold then as it is now, and I know that it has hit at least -15 in parts of greater manchester, especially near the Pennines. I'll bet that the deisel supplies then were not blended for temperatures for even -10. There could be a slim possability of waxing, which can have similar symptoms to all of the above. Don't rule it out Just a thought. On 26th Oct, 2004 TurboDave16v said:
7th Dec, 2010 at 10:48:39pm
A bit of a tangent, but the cold we are having is definitely having an effect on diesel. I know this as my diesel space heater which will usually fire up first try, is now taking some real persuasion, to the point that I had to feed it warm air from my hot air gun tonight to get it to fire up. Once off it was then really smokey for a while, however the lob a bit of meths in trick did really seem to help.
8th Dec, 2010 at 05:28:05am
check the upfill pump, disconnect fuell filter end and switch on, it should flow like a tap.
112 Posts Member #: 7030 Advanced Member Bucks |
8th Dec, 2010 at 11:01:43am
Sprocket that tip about diesel waxing was interesting, it might explain a problem I had with my TD car the other day which I hope hasn't caused any damage e.g to the pump or bearings. Hmm what to do to minimize waxing may be a concern for people living to the north still in the throws of lower temperatures. |
8th Dec, 2010 at 11:35:31am
A mate showed me a bucket of waxed deisel last week- never seen that before so wasn't surprised he fecked his pump
8th Dec, 2010 at 08:28:54pm
When those little blanking caps crack or split they general cover the entire engine bay with diesel! Makes a right mess, silly design.
On 7th Dec, 2010 BENROSS said:
dave as above but ..... dont disregard the slippage hoses which are connected to each injector and to the next one and the blanking one on the end these perrish and or split and cause this classic problem you describe. On 19th Jan, 2010 wil_h said:
8th Dec, 2010 at 09:52:00pm
On 7th Dec, 2010 Tom Fenton said: Used to work for dad when he used to go to russia in the winter. However he also had to set a fire under the diesel tank if he stopped for any length of time (still couldn't turn the engine off or it would never restart)
the lob a bit of meths in trick did really seem to help. If something is worth doing, it's worth doing half of. |
9th Dec, 2010 at 05:18:00pm
a new filter will def come with one dave, but as long as its there, and firmly clipped into the top of the filter, it should do its job fine?
9th Dec, 2010 at 06:47:53pm
Ah...you never have to bleed the injector side of the pump on a di lump. As long as it bleed up to the pump & turned the engine a few times, should fire into action. On 9th Dec, 2010 joeybaby83 said:
a new filter will def come with one dave, but as long as its there, and firmly clipped into the top of the filter, it should do its job fine? jason, might be a daft design but...when bleeding the injectors once, i managed to clumsily snap off the feed to the front injector, fortunately a blob of araldite, and swapping the hose to the other un-used one saved me a right headache, so from me, they get a thumbs up lol On 19th Jan, 2010 wil_h said:
10th Dec, 2010 at 11:21:14pm
cracking the injectors off has done the trick a few times for me?
11th Dec, 2010 at 05:52:26pm
What age is this tranny? If it a CRD we don't want to be cracking injectors etc due to the fuel line pressures involved please On 5th Sep, 2011 Vegard said:
11th Dec, 2010 at 06:01:09pm
One of the lads who used to work for us (God rest his soul) told me a story that when he was in the Navy, he maintained and repaired helicopters. He then went on to to tell me that one of his mates, while working on a Chinook, he found a leak from one of the hydraulic hoses, only a pin hole squirting out fluid about 20ft across the daeck. He put his thum over the leak, and the fluid promptly found its way through his thumb too!!
11th Dec, 2010 at 06:01:44pm
^Ouch! If something is worth doing, it's worth doing half of. |
11th Dec, 2010 at 06:05:33pm
crackign common rail lines is fine, do it all the time to bleed them by the time enough diesel has escaped to meerly wet the fitting its down to 3-4 bar at most. that said, the fittings do have a finite number of uses (1 if you ask bosch) and after a few goes may stop sealing. turbo 16v k-series 11.9@118.9 :)
12th Dec, 2010 at 09:22:58am
Transit DI isn't common rail. Like I said before, you don't touch the injector side of the pump. All bleeding/priming is done on the filter side. On 11th Dec, 2010 evolotion said:
crackign common rail lines is fine, do it all the time to bleed them by the time enough diesel has escaped to meerly wet the fitting its down to 3-4 bar at most. that said, the fittings do have a finite number of uses (1 if you ask bosch) and after a few goes may stop sealing. On 19th Jan, 2010 wil_h said:
