Home > Help Needed / General Tech Chat > Mega jolt trigger wheel
NickG
Member #: 7912
Australia oi oi oi!
So I have put my trigger wheel 180 degree out tdc. Lol oppss!
I'm going to fix this up today.
Is it ok to leave the mini in 1st gear when I undo the
Harmonic balancer nut? Or do I need to jam the flywheel
To stop it spinning? I don't want to cause damage.
What is the torque setting when doing it back up?
Lastly will I need to re do my timing ? If I'm not touching
The dizzy is should be fine right?
Thanks! *happy*
paneermeel
Member #: 1404
The Netherlands
Why do you still have a dizzy when you are going to use MJ?
there is nothing wrong with a A-series that a turbo can't fix.
www.turbomini.nl
You'll need to lock the flywheel to get the nut undone, you'll just end up running yourself over with it in gear *wink*
NickG
Member #: 7912
Australia oi oi oi!
Dizzy is still in as I drive the mini everyday.
Will convert to mega jolt as soon as I can get it working *wink*
Flywheel check! Just use a screw driver?
I have done in the past, but I have a locking tool now, some people use an old shell..
paneermeel
Member #: 1404
The Netherlands
Picture:)
www.turbomini.nl
its too cold to get it out now *tongue*
Bodge Job
Member #: 953
London
*laughing*
