| Home > Help Needed / General Tech Chat > Inlet manifolds | |||||||
11th Dec, 2010 at 03:01:24pm
When the A35 was normaly aspirated I used a Janspeed inlet manifold, which I still have.
11th Dec, 2010 at 03:19:45pm
I can't see why not dave. If something is worth doing, it's worth doing half of. |
11th Dec, 2010 at 04:48:25pm
don't know about the manifold issue but 165bhp in the A35 is going to be lots of fun! |
11th Dec, 2010 at 06:11:47pm
If realised,(IF !) I will need some £200 half shafts, but these stick out so that I cant use the chrome hub caps and that loses me my stealth capability. |
11th Dec, 2010 at 06:14:17pm
I presume your already on shafts from somthing like a midget? On 28th Aug, 2011 Kean said:
11th Dec, 2010 at 06:22:11pm
Yes, Midget shafts and I have half a dozen spares, but its not that convenient to change them at the roadside if one goes.
11th Dec, 2010 at 06:24:27pm
Ah, I see,
11th Dec, 2010 at 07:17:06pm
What do the experts reckon if I was to cut or turn off the thread and weld the flange to the taper ?. |
11th Dec, 2010 at 07:33:51pm
I would be reluctant to weld to it if it is known to break, the weld procedure will leave a heat affected zone.
11th Dec, 2010 at 07:37:50pm
maybe reduce the sticky out bit as much as possible and add a small wheel spacer? On 28th Aug, 2011 Kean said:
12th Dec, 2010 at 03:36:08am
I understand the effect of the weld, but it would be only on the very end of the shaft, well away from the taper and the usual area where they are stressed (the part just inside the wheel bearing, which is a semi floating arrangement)
