Home > Introduce Yourself > new user
midasracer
Member #: 9247
Hello,
I just signed up to learn about megasquirt and megajolt. I have a MED1293 turbosprint in my Midas convertible with lots of mods on it. But I can't get the timing and fuel consumption right. I've heard a lot of these new systems and am very interested to find out how it works to get the most out of my engine. Here's a short vid of my car:
http://www.youtube.com/watch?v=13BO5lPNgRg
I have to say, that after this vid I found out the overpressure valve in the intake manifold still working. This was killing the power when the boost (14psi) came in. That's blocked now, so it's a lot quicker.
I have cured the heat problem although in traffic jams the brake lines get too hot, I'll be installing a Renault 5 turbo fan to cure this. Also too much play on the crankshaft and I want to replace the straight cut drop gears with quieter ones and want to replace the 3.1 diff with a 2.9. So when I have all the bits the engine will come out (again) for overhaul and upgrade.
Edited by midasracer on 13th Dec, 2010.
looks and sounds nice, Welcome to TM!!!
hi and welcome to TM mate.
Mini_the_minx
Member #: 9077
Cheshire
Hi there
On 2nd Nov, 2010 wil_h said:
Welcome
hello and welcome
welcome to TM
welcome to TM
enjoy.
turbominij
Member #: 2104
Essex - UK
hello and welcome
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
hazpalmer
Member #: 9038
Carlisle, Cumbria
welcome
