| Home > General Chat > roller rockers | |||||||
461 Posts Member #: 9229 Senior Member newcastle upon tyne |
18th Dec, 2010 at 09:39:58am
Hi has any 1fitted roller rockers without doin the head gasket? Does it work? Thanks scott |
![]() 716 Posts Member #: 9077 Post Whore Cheshire |
18th Dec, 2010 at 09:53:13am
For the price of a head gasket is it really worth risking it go? On 2nd Nov, 2010 wil_h said:
I think it's probably a given that all people who own pink cars like it up the Gary. On 14th Jan, 2011 rubicon said:
please dont put a batty kit on it, il have to by internet law, Report you to barry boys.com |
18th Dec, 2010 at 11:14:51am
I've done it a couple of times. Got away with it once didn't the other. If something is worth doing, it's worth doing half of. |
18th Dec, 2010 at 11:45:08am
i have never had any problems..... as there is enough. tension with the remaning front head studs
1391 Posts Member #: 1686 Post Whore Oxford |
18th Dec, 2010 at 12:44:31pm
Out of principle i would change it due to it being de compressed at certain points. Its not much work to swap over a head gasket.
OMG Robert that's a big one |
18th Dec, 2010 at 03:18:19pm
I,ve done it several times - just drain the water, take the tension off all the head studs and then re-torque afterwards -never had a problem. |
18th Dec, 2010 at 04:18:36pm
The only reason I was wondering is I havnt got a head gasket to hand & I prob not get 1till after xmas now so thought I mite get away without doin it |
18th Dec, 2010 at 04:57:33pm
On 18th Dec, 2010 tadge44 said:
I,ve done it several times - just drain the water, take the tension off all the head studs and then re-torque afterwards -never had a problem. Ive done the same and got away with it in the past. but if your N/A its not that much more work is it? I run a supercharger and I don't care the TB is on the wrong side.
18th Dec, 2010 at 05:26:52pm
Its a metro turbo so plenty room for working so not that much of a head ache either way |
