Home > Technical Chat > Balance Tube on Twin Carb/TB Inlet Manifold
How critical is it to have a balance tube between the inlet runners?
Anyone tried with or without?
I notice that Weber manifolds rarely, if ever, have one.
TurboTom
Member #: 7936
DK-8450 Hammel. Denmark
If you are thinking about the balance tube on the double SU manifold, then as far as i know. Bloked pipe gives more low end power and less top end power. Open pipe, less low end power and more top end power.
Opel (maybe vauxhaull to) had a valve on the 6 cylinder Omega in the early ´90 that opened and closed at 3000 rpm in order to give the best off two worlds.
If i have more toys than you when i die, I WIN
TurboTom
Member #: 7936
Try to take a look in santa´s presant on page 443.
There´s an explanation
It does indeed.
You are doing very well if you have got to page 443 already.
Fantastic read. Throw away any of the old theories about engine wave dynamics and start again. I'm going to get the companion volume soon.
Disk full (/tmp/#sql_c9d4b_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
