Home > Help Needed / General Tech Chat > Turbo selection!!!
miniman03
Member #: 7642
Gillingham, kent
Hi people,
I have a metro turbo engine with a T3 garret as u all know. its started blue smoking and was told that it was suspect of turbo. ive had a look on the net but i cant seem to find new ones for metros. i was wondering if it was possible to buy any t3 with ball bearings and swap the turbine housings over.
Is this possible? if so could i have some help or direction what kind of turbo i should be buying.
Thanks jay
turbominij
Member #: 2104
Essex - UK
t3 turbos vary from car to car i dont know which ones are the same however
these guys do standard replacement turbos give them a call as its not listed on there website
http://www.btnturbo.com
other than that you have turbo technics and cr turbos who do hybrid and standard turbos
http://www.turbotechnics.com
http://www.crturbos.co.uk/
else a decent motor factor will be able to get you one. but chances are they will go to one of these guys and then charged you for the privilege
Edited by turbominij on 20th Dec, 2010.
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
