Home > Help Needed / General Tech Chat > carb help
Hi lads,
Well I am rebuilding my carb at the min and i have some questions about the outlets I need confirming.
A. Can i drill this out and put a grub screw in there
B. Fuel in
C. and can i grub this to
D. what is this for
Thanks lads as always.
Simon
dazibee
Member #: 1356
TRURO, CORNWALL
Connect D up to your Megajolt vac pipe
We found that the van's engine was better below around 10psi with A and C connected (part throttle lean off), above that we had to block it. How much boost are you going to run?
B. Yes
D. Is usually the vac advance take off for the dizzy
Edited by apbellamy on 18th Dec, 2010.
I am sorry if its a bit school boy but i am not upto speed on this lot as for as for boost i am hoping for around the 170BHP mark.
Quite a lot then! Personally I would leave them and then blank them of if it helps things on the rollers
ok then its just my OCD gurbs look smarter
and lighter!
