| Home > Help Needed / General Tech Chat > OT - Diesel Injector Servicing | |||||||
19th Dec, 2010 at 11:53:23am
Continuing the work on my Citroen I have found what I suspect to be a faulty injector. I have found a few places on the net that will service them and a few second hand units on Ebay.
http://www.twin-turbo.co.uk
19th Dec, 2010 at 12:08:03pm
by the time you have done ben, save some cash and time, get one from the scrappys, one from a accidend damaged prefered...............
19th Dec, 2010 at 12:59:35pm
You could try whellam diesel in Leicester, used them to get injection pumps serviced in past. There is a place just off the 46 that does diesel service but can't remember the name! |
19th Dec, 2010 at 03:37:00pm
This is a long story, but basically the engine broke a lifter and a rocker therefore became loose in the cam cover. this made friends with another rocker which jammed down the valve. This all resulted in a broken piston and a poorly head. I now have it all back together, but the piston that it all happened on the injector is not working, not surprising really.
On 19th Dec, 2010 BENROSS said:
by the time you have done ben, save some cash and time, get one from the scrappys, one from a accidend damaged prefered............... whats the problem you have buddy ? Edited by Ben H on 19th Dec, 2010. http://www.twin-turbo.co.uk
