| Home > Help Needed / General Tech Chat > Mega jolt running rough.. ** now working!! next question! | |||||||
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
20th Dec, 2010 at 10:58:49am
I set up mega jolt and the it started first go! He wheel is sitting top
Edited by NickG on 27th Dec, 2010. |
20th Dec, 2010 at 11:03:09am
When you say the wheel is sat TDC, what do you mean?
20th Dec, 2010 at 11:42:39am
I using ben92"s who does the sc12 kit
20th Dec, 2010 at 11:46:53am
If no maps are loaded then it'll be running at 0 degrees and VERY rough!
89 Posts Member #: 2380 Advanced Member Hamburg, Germany |
20th Dec, 2010 at 11:51:55am
unplug the MJ box, it should be running with 10° btdc by default. should be quite smooth, at least all my engines are running good with 10° at idle.
20th Dec, 2010 at 08:44:06pm
nick load the map I gave you and re try.. I run a supercharger and I don't care the TB is on the wrong side.
20th Dec, 2010 at 09:04:17pm
Thanks I will try that today. I have not loaded the map you gave me Graham as I'm still na. I just want to sort the mega jolt first.
21st Dec, 2010 at 12:21:13am
i unplugged my MJ unit and the car wont start in limp mode.
Edited by NickG on 21st Dec, 2010. |
21st Dec, 2010 at 07:55:59am
if it won't start in limp home you have something wrong with the hardware set up, i would say.
21st Dec, 2010 at 08:50:18am
i think you need to start from the beginning, check you have a power supply to the mj, check your wiring pip and saw and check you have a small amount of voltage to these. check you have the ht leads on the right plugs and have a strong spark, check your timing and vr sensor is at the right gap and position. |
21st Dec, 2010 at 10:54:49am
If the dizzy is not connected to the spark plugs it is doing nothing. It cannot effect the timing at all.
On 21st Dec, 2010 NickG said:
i have not taken my dizzy out, just unplugged power feed. it still has what ever advance set etc when i got it tuned? would i be right in thinking that the dizzy is still trying to mechanical advance? while my mega jolt is trying to spark etc. totally mucking things up? i did a search i timing could be a problem also. http://www.twin-turbo.co.uk
21st Dec, 2010 at 10:56:58am
Ok, I will check. The software advance
1050 Posts Member #: 764 Post Whore Staffordshire |
21st Dec, 2010 at 12:45:56pm
I'm not trying to be an arse, but I think you should let someone with some megajolt experience have a look. |
21st Dec, 2010 at 12:53:28pm
Hi Anton all good.
21st Dec, 2010 at 12:54:49pm
if it runs with the MJ box connected what does the timing light shows?
21st Dec, 2010 at 04:49:09pm
I would first check the gap from the VR sensor to the trigger wheel and then ensure that the connection from the VR sensor to the EDIS is shielded and the shield is earthed at the EDIS end.
22nd Dec, 2010 at 07:55:13am
right so i sorted the starting issue.
22nd Dec, 2010 at 08:25:46am
something wrong here, the coil should not do that. check you wiring I would say. |
22nd Dec, 2010 at 08:57:08am
common problem with the coil packs im told. in hot climates.
22nd Dec, 2010 at 09:46:39am
Have you definitely wired it up correctly?
22nd Dec, 2010 at 10:25:35am
the harness is a sd mini harness. the sensor looks to be sitting to the left & not in the centre of the trigger wheel.
22nd Dec, 2010 at 11:23:55am
ideally the centre, but i suspect aslong as the centre of the vr is picking up a signal then it should be ok, put a voltage meter on, you should get a very small reading. the vr should be abt 1mm gap. |
22nd Dec, 2010 at 12:31:14pm
thanks for the reply i tested it today.
22nd Dec, 2010 at 12:35:29pm
When the engine is at TDC the missing tooth should be at the top (12 O clock) and providing the sensor is at exactly 90 derees BTDC (9 O clock) it should be pointing towards a tooth.
![]() 453 Posts Member #: 6449 Senior Member Brisbane, Australia |
22nd Dec, 2010 at 01:49:56pm
Me and nick had a play with it today.
In boost we trust |
