Home > Help Needed / General Tech Chat > gearbox
nogin
Member #: 487
westbury, wiltshire
silly question but do you need to use a turbo gearbox on a turbo 1275, ar all the box shells the same or do some have strengheners in them, eg can i use a box from a 1098 to build a box for a turbo 1275 cheers
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
Box casings as you say, are all the same.
turbo hogster
Member #: 178
stowmaket suffolk
as long as its a a+ box then yes, if it a a series then the idler is smaller than the 1275 and a+
minimark
Member #: 19
newcastle
so you get a reducer
nogin
Member #: 487
westbury, wiltshire
so whats this reducer you speak of, easier then just sourcing a different box
i also make things
You can get an idler bearing that allows the use of A idlers in A+ boxes.
The only trouble is fitting a 1275 engine on a NON S 3sync box. that just doesn't work!
nogin
Member #: 487
westbury, wiltshire
so i wouldnt be able to fit a 1275 block onto my 1098 gearbox box is from a 1981 car, all gears ar guna be changed just want to use the shell if possible
i also make things
yes you would be able to do this. If you are buying all new gears anyway then just get the correct ones for the gearbox casing e.g. A or A+ type. From memory none of the 1098 engines were A+.
The last of the clubby estates were 1098 A+.
I didn't believe it till I saw one!
nogin
Member #: 487
westbury, wiltshire
it came out of a clubby estate, any way i could tell if it was a a + type
i also make things
yes look at distributor. If it is held by a forked clamp with one bolt it is A+.
If it has a clamp that tightens up around it to hold the dizzy (that fits in a seperate collar) with 2 bolts securing it then it is A series.
Edited by Tom Fenton on 7th Mar, 2005.
turbo hogster
Member #: 178
stowmaket suffolk
plus the box would use the larger idler gear bearing
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
TH?
You sure?
alex
AlexF
A+ boxes have got the larger idler.
But, you may fit an A idler with the correct bearing in an A+ housing.
http://www.minispares.com/Product.aspx?pid=38305
Edited by Vegard on 8th Mar, 2005.
nogin
Member #: 487
westbury, wiltshire
ah ha then it is an a plus a bonus then as i have the gear box shell i need, cheers buds
i also make things
A+ isn't neccesarily a bonus. The A ones are just as good.
Disk full (/tmp/#sql_c9d4b_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
