| Home > Help Needed / General Tech Chat > Panel captive nut fitment | |||||||
26th Dec, 2010 at 07:38:40pm
Ive been supplied some of these to use with my bulkhead panel. They are for the centre speedo pod screws.
432 Posts Member #: 7856 Senior Member Essex |
26th Dec, 2010 at 09:31:57pm
Assuming the inner face (that is the non-hex side) is bevelled inwards then these are what I used to use at work for feet on metal units.
26th Dec, 2010 at 10:37:01pm
They are bevelled inwards. These will be fitted to a 1.5mm sheet of steel so I won't be able to couuntersink, but im guessing they will work fine anyway? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
337 Posts Member #: 9138 Senior Member wolves |
27th Dec, 2010 at 12:38:19am
wouldn't rivnuts be easier ? |
27th Dec, 2010 at 07:34:08am
Thats called a hankbush. Drill a hole insert the round sleeve bit and peen it over. Astons had hundreds of those fitted to them I seriously doubt it! |
27th Dec, 2010 at 10:08:56am
I rivnut would be easier to fit, but these look closer to what was originally fitted. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
27th Dec, 2010 at 10:17:34am
Run a bolt down the wrong side with a washer and crush it into the hole? On 11th Feb, 2015 robert said:
27th Dec, 2010 at 11:46:19am
Start it with the rounded end of a ball peen hammer, then use the flat end I seriously doubt it! |
