Home > For Sale > mini shell
100ev8
Member #: 9138
wolves
the front is bent !!! but everything from the stick hole back is good and needs no welding , ideal trailer or cut and shut if you fancy that sort of thing . id is included if you want it bit its a cat c recorded . must be gone by jan 4th . £50 . located in wolverhampton
http://www.fishfight.net/
maccamcvey
Member #: 6673
Worral Sheffield
could be interested any pics?
maccamcvey
Member #: 6673
Worral Sheffield
100ev8
Member #: 9138
wolves
will take some in the morn , no wings , front panel , inner flitches or anything on it as i had to cut um off to get the engine out
only pic i got atm but it will be bare shell only
Edited by 100ev8 on 29th Dec, 2010.
maccamcvey
Member #: 6673
Worral Sheffield
I assume this is from before the crash? how old is it?
100ev8
Member #: 9138
wolves
after the crash !! the front looks much better than it really is. took it in the drivers A post , moved the n/s pillar out , dash rail is in about 3" , bulkhead out twisting the x menber , pedal box frame twisted where it mounts . front is very bent from the stick hole forward
maccamcvey
Member #: 6673
Worral Sheffield
sounds more fucked than I hoped *frown*
Johnny
Member #: 6926
Accrington
for £50 you can sell most of it on in bits for a hell of a lot more, i would buy it if i had the space!
clubman91
Member #: 8923
North Wales
hes said its only going to be a bare shell
