Home > Technical Chat > Kad alloy rear arms , weight
gents, although ive had one in my hand in the past i never weighed it, does anyone know the weight excluding pin,
aslo whats the weight of a standard cast iron rear arm, iv'e got 11lbs in my head somewhere from way back,
cheers carl
Lighter than yours. ha ha ha
shut the f-ck up tea tray spoiler boy,lol
Johnny
Member #: 6926
Accrington
just weighed mine, doesnt have the pin in for the hub... it came to approx 6kg
Keith Timpson
Member #: 3104
Carl, not exactly what you are looking for but it's a start. Weights are for the arms complete with pin for the hub and the pivot pin.
Standard arm - 13.4kg
KAD alloy arm - 8.5kg
Weights are to the nearest 100g weighed on my bathroom scales so not 100% accurate.
Hope this helps a bit.
Cheers, Keith
14.914 sec 1/4 mile @ 91.38mph, NA 1293cc on 1.1/2" SU's (all steel and glass shell)
Keith Timpson
Member #: 3104
Carl, on second thoughts I might be talking shit!!
Can't remember if that was built up with brakes or not. I've a feeling the standard arm was with a cast iron drum and hub and the KAD arm was with an alloy drum and hub. Too long ago to remember and too late at night to think straight !!
I would ignore everything I've said, I'm sure somebody will come up with a better answer!!
Keith
I dont have time to search right now as Im going out to work but I remember John Kimmins posting the weight of one of his arms years ago which stated the weight of KAD aswell. I believe his was very slightly lighter
Paul
alaskanow0
Member #: 8466
Mansfield
Standard cast arm, with pin 5.74kg, rear hub 1.3kg & backplate 0.82kg. Don't know about KAD but have some on order that I can weight on arrival. Anyway why do you ask Carl?
Edited by alaskanow0 on 31st Dec, 2010.
rosco454
Member #: 5222
Northumberland
I searched and could only find figues for the standard arm,bare with no pin - 5.53kg.
Cheers Ross.
thank's gents, the 5.5kg is not far off my origional thoughts .
iv'e fpound a like for the KAD arm at 2.95, i'll assume this must be with pin fitted,
i'm just trying to compare my stuff to others, [info for my site]
i might have a look into billet aluminium arms,
Could you make a set of light weight rear arms that would work with rubber cone suspension? I'd be interested in a set if you could - currently considering the KAD ones for my car.
ditto
interested too
would need to be strong though strong enough for a full fat car and full fat driver!
I'm not fat, I have heavy bones lol
in TI yes readily available, in billet alloy, is doable in two different ways, but not easy in either,
carl
how much for the ti jobbies mr A?
not less than £800 a pair, as per my site prices,
well, 2 sets of scales , 2 different results,
some TI pin monut coilover rear arms ive just amde up weighed 1.8kg without pin on my[ read wifes] kitchen spring balance tyre scales, but took them to the workshop with pin fitted and they weighed a few grams under 2kg on my digital scales,
obviously i'm going with the digital scale weight ,lol
carl
carl
