Home > For Sale > New Year Clearout - Loads of Engine Bits
01smartc
Member #: 2563
Tamworth
Hi all,
Having a bit of a clearout at Smart Performance.
Got loads of engine bits that need to go to make some room.
Here is a quick list of what ive got, ive got loads more so if its not listed then just ask i might have it.
1275 heads - £40 each
998 heads - £25 each
998/1275 blocks (various sizes/conditons) - £50 each
Brand new piper cams - £65 each various profiles
Sets of rods - £30 each
Simplex timing gear - £5 each
Valve springs - £5 a set
Loads of other stuff so just ask.
Also got a couple of machines for sale
Elliot Omnispeed lathe - £1000
3-phase pillar drill - £250
And an Alipnestars racesuit - done 5 races, really good nick. Cost me nearly £700 -- looking for £450
Few V8 bits aswell if you just ask me
Cheers Chris @ Smart Performance
scott the joiner
Member #: 9229
newcastle upon tyne
Hi there have you any vernier duplex sets? Any cams suited to a turbo sumthing on the lines of a phase 2 many thanks scott
Ozyris
Member #: 9054
Disneyland Near Paris
do you have 1275 head with big vlave ? (36/29) thanks =)
Which Piper cam profiles have you got? If you've got a 285, I'll have one.
svrdaniels
Member #: 3600
Gateshead
Do you have a pre A+ 1275 block that has not been bored or skimmed?
01smartc
Member #: 2563
Tamworth
We have got duplex sets.. brand new at £25 a set
Sorry no big valves heads
We havnt got any 285 as thats our most popular cam.. however I could get one in for you quite easily if you want?
Will check on the block today and get back to you
Cheers Chris
turbominij
Member #: 2104
Essex - UK
do you have any LSDs?
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
mikko
Member #: 5393
Belfast
any oversized pistons matey?
PaulH
Member #: 2340
Dublin Ireland
Dont supose you have any Piper 320 profiles ?
On 17th Feb, 2009 Rob H said:
01smartc
Member #: 2563
Tamworth
No lsd's.
What oversize and spec pistons?
Ive got BP300 in stock but could sort a 320 if your desperate?
Chris
Leepol83
Member #: 9081
Hi mate have you got any standard metro turbo plenum chambers up for grabs
Cheers buddy.
mikko
Member #: 5393
Belfast
would consider anything, block needs a rebore due to rust so was thinking the bigger the better and some 1380 pistons i won on ebay are cracked
greggy50
Member #: 8937
Any 1275 block's left? or bits to build up a 1275 engine?
