Home > Wanted > Wanted a couple of turbo bolts/studs
fasteddie84
Member #: 9072
Jersey, Channel Islands
Hi
As post says, I am after the stud in this picture:
If no-one has one, does anyone know the measurements?
Also after the medium sized bolt that connects the exhaust elbow to the turbo:
Finally, after the 5 studs that connect the exhaust flange to the exhaust housing as seen in this picture:
Thanks all
Speed doesn't kill, suddenly becoming stationary, now that's what'll get ya!
Star Mag
Member #: 375
Leicestershire
Nuts for manifold are m10 I think, bolts for other parts are m8 just need to measure the lengths.
Ron
jamestar
Member #: 9159
Devon
yep nuts are m10, studs are 37mm long.. ebay is your friend :)
fasteddie84
Member #: 9072
Thanks guys, thought they would be some weird imperial size.
Will buy some M8 and M10 bolts locally first and make sure they fit before buying the correct length etc.
Also, anyone where I can buy the triangle shaped exhaust elbow gasket?
Ta
metroturbo
Member #: 989
North Yorkshire
Avonbar sell the gaskets. http://www.avonbar.com/prodMain.aspx?range...Id=227&makeId=0
