| Home > Help Needed / General Tech Chat > A couple of problems help needed ?? | |||||||
20 Posts Member #: 9034 Member |
8th Jan, 2011 at 05:28:26pm
Hi I've managed to replace my gearbox as I blew up the diff!
8th Jan, 2011 at 05:33:12pm
You are correct about the pipes.
8th Jan, 2011 at 05:42:01pm
You sure that pipe off the bottom of the turbo isn't the oil drain?
Edited by almichie on 8th Jan, 2011. On 7th Nov, 2011 apbellamy said:
8th Jan, 2011 at 07:51:25pm
Thanks for the info that's a big help no its not the oil drain it's as small as vacuum pipe 3 maybe 4mm I can check the lead sequence now aswell |
