Home > For Sale > Omex ecu
I have an omex 100 series ecu complete with loom and crank damper with 36-1 ring attached.
I have been running this ecu as ignition only however the loom is a 500 series injection loom and the 100 series can be upgraded to 500 spec with a software change from omex so you can run injection if you wish.
I do have the serial connector for programming but have lost the programming manual, these are available from omex.
The ecu is already set up for a turbo mini and was setup by slark.
No sensors included
£175
Edited by wolfie on 10th Jan, 2011.
PaulH
Member #: 2340
Dublin Ireland
I'll take this Wolife if it's not all ready gone :)
On 17th Feb, 2009 Rob H said:
PaulH
Member #: 2340
Dublin Ireland
Wolife does this ecu have a rev limiter built in, I cant see any reference to it in the 100 series manual on there sight?
i am 99% sure it has both soft and hard cut, i remember slarks asking what rev limit i wanted
