Home > Help Needed / General Tech Chat > ignition timing
johnrg
Member #: 7788
bradford west yorkshire
hi again guys i need some help to able me to set my ignition timing on my 1275 a+ it has points not sure if this makes a difference how hard is it to do as ive never done 1 of these before thanks
Have you got a haines manual and a timing light?
you need a stobe, i would set the ignition timing at 6 deg before top dead centre at 1000 rpm, with the vacume pipe disconected from the distributor cap for this purpose, use number 1 lead
the big pointer on the thing chain cover is TOP DEAD CENTRE and for every pointer back after the is 4 degrees
make sure you set the points gap @ 0.015" or 0.4mm first!
there are many other websites showing you just how to using a strobe ... maybe the haynes manual is a good start...... just google it
hope this helps
johnrg
Member #: 7788
thanks guys yes i have a haynes manual but no strobe light i will let you know how i get on
