| Home > Help Needed / General Tech Chat > electrical problem help needed | |||||||
173 Posts Member #: 9184 Advanced Member lancashire bolton |
13th Jan, 2011 at 11:38:02am
Hi all. Got a metro turbo that won't start got mobile car electrician out around a month ago all it was was the wire on the starter motor was loose then the freeze came and had not turn the metro over so thought it best to so wouldn't seize over wouldn't turn over then suddenly 5minutes into trying to start her suddenlly she starts cranking her self over didn't start but turn ignition off but still cranking so had to switch it of by the kill switch fitted quick breather lol so went start today and I turn the battery on through the kill switch and all dashboard lights come on but won't turn over checked the starter motor wire nice and tight then notice wen battery on a small black box with 12v 30a on it starts to smoke as soon as I turn the battery on and help would be great ps sorry for the life story |
13th Jan, 2011 at 11:43:02am
and breath..........
13th Jan, 2011 at 11:47:12am
Lol any idea about the smoke little box or could this be linked to a sticky solenoid |
13th Jan, 2011 at 11:50:41am
you've burnt a relay out for the ignition and starter circuit. our van does it sometimes On 11th Feb, 2015 robert said:
13th Jan, 2011 at 11:57:45am
sorry - didn't see the bit about the box - Andy is quite right. |
13th Jan, 2011 at 12:09:58pm
Is this an easy fix. Any one no where I can get this part. Cheerd |
13th Jan, 2011 at 12:13:09pm
pull the relay out, push the new one in. motor factors should have one On 11th Feb, 2015 robert said:
13th Jan, 2011 at 12:18:21pm
Cheers mate sorry no machanic bought this car drove it home then nothin but problems only had down the drive once |
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
13th Jan, 2011 at 12:50:19pm
On 13th Jan, 2011 sean g said:
Cheers mate sorry no machanic bought this car drove it home then nothin but problems only had down the drive once You should have read the AD then, Most on here are familer with the metro you bought....... i must say there was better out there.....:( On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
13th Jan, 2011 at 12:57:47pm
Ano ye is a v fast little car from my test drive home lol |
461 Posts Member #: 9229 Senior Member newcastle upon tyne |
13th Jan, 2011 at 05:44:21pm
Hi there my metros been nothing but problems either its part of the fun lol I've had a similar problem tried starting my metro turbo the other day & the starter was spinning but wouldn't crank the motor then all of a sudden was working fine so presume a sticky starter & I had the cranking problem when the key was off & it was just the goldy coloured relay fixed to the battery tray was damp after a day in the airing cubard problem solved hope this helps |
13th Jan, 2011 at 07:21:48pm
Cheers scott I'll give it ago
14th Jan, 2011 at 10:06:31am
I think you are going to need your own sub-section in 'help needed'.
In the 13's at last!.. Just |
14th Jan, 2011 at 10:38:55am
Tell me about u lot the fellas in the no thou |
15th Jan, 2011 at 09:17:58pm
Any one no anywhere I can get a complete loom for my metro turbo.
15th Jan, 2011 at 09:41:18pm
why do you need an entire loom? |
