Home > General Chat > small cosworth turbo
sean g
Member #: 9184
lancashire bolton
Any 1 fitted these to there 1275 engine. Good idea? laggy or not and help would be great. Cheers
Ben H
Member #: 184
Melton Mowbray, Pie Country
I think you will need to tell us exactly what the turbo is. There are lots of cosworths.
http://www.twin-turbo.co.uk
Are you asking because you have fitted one?
more ''laggy'' than a metro t3 as the gas turbine is larger...
sean g
Member #: 9184
lancashire bolton
A small turbo escort belive its a t25 as far as what I have fitted not to sure gonna take it off this week very laggy thou
was there an Escort smaller than the standard run of the mill Escort?
Just because it might be a T25, doesnt mean that the turbo is 'small' Certainly the T25 fitted to the late escort Cosworth was smaller than the early T3, but its still big when considering its use on a 1.3 A series. The early Escort cosworth used a laggy (when talking about the escort) T3 with an A/R of 0.60. Not sure what the late Escort cosworth A/R was. The escort Cosworth T3 on a 1.3 A series would be just ludicrous
Basically, A Metro Turbo T3 was considered 'laggy' so anything bigger will be even more so.
Edited by Sprocket on 14th Jan, 2011.
sean g
Member #: 9184
lancashire bolton
Ok cheers for you help so if any thing down size lol
Yes. Look at GT1752, TD04 or if you want something a bit bigger GT2056
