Home > For Sale > A series \"go faster\" bits
Owen
Member #: 6496
Somerset
Got some left over A series bits kicking around that need a good home!
MED Low Distortion 1.5:1 roller tip rockers. Seen about 500 miles - £230 posted.
MED dynamic 'S' damper. Seen about 300 miles - £110 posted
Complete megajolt (V4 iirc). TPS version. Taken off a running 1380 engine.
Includes:
ECU
Loom
'S' pulley and damper with trigger wheel (wheel on pulley not damper)
Crank sensor
Crank sensor bracket
TPS sensor
TPS bracket (for weber 45)
EDIS unit
Coil pack
Coil pack bracket (fits on head stud)
HT leads
Butt plug
£350 posted (has been mapped for a 1380 race engine).
O.
Edited by Owen on 26th Jan, 2011.
On 9th Feb, 2010 joeybaby83 said:
yep, ball in a tube affair
Owen
Member #: 6496
Somerset
Also got a weber 45, jetted for a 1380 race motor (286, rockers etc).
sausage-man
Member #: 7738
nothern ireland
is the megajolt ready to bolt on and setup?
Owen
Member #: 6496
Somerset
The only thing that might need fiddling is the TPS bracket as that's for a weber with a "side" linkage (the black one). Everything else is ready to go. Was removed off a running car!
Owen
Member #: 6496
Somerset
Jolt set up now £350.
Owen
Member #: 6496
Somerset
Anyone interested in indivudual bits of the megajolt...might consider splitting.
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
I'm looking for a crank pulley with sensor barcket.
fab
blister
Member #: 2590
Croydon
i am looking for a crank sensor bracket and trigger wheel and info on the weber mate?
Owen
Member #: 6496
Somerset
Any takes for any of the other bits? Everyone seems to be after the trigger wheel and sensor!
Weber was taken off a running mini. It is mounted on a brand new maniflow 7 inch steel intake manifold which has been modified for an evacusump set up.
It was set up at Slarks on a 1380 not too long ago.
Also has a brand new ITG filter (lost the clip somewhere in my unit but will get on the case to find it).
All mounted on fresh rubber gaskets and mishap rubbers.
Twin cable linkage. Also the TPS bracket is made to fit this linkage *wink*
Pics:
