| Home > General Chat > Installing Supercharger without pulling engine? | |||||||
44 Posts Member #: 9074 Member |
14th Jan, 2011 at 05:56:32am
Hello,
![]() 716 Posts Member #: 9077 Post Whore Cheshire |
14th Jan, 2011 at 08:12:49am
Unless you have a removable front end then you'll need to pull it out. You'll need to mock up space and placement for different parts and it's a pain in the arse attempting it with a hefty piece of tin/FG/CF in the way. Plus you always run the risk of smacking something onto the bodywork. On 2nd Nov, 2010 wil_h said:
I think it's probably a given that all people who own pink cars like it up the Gary. On 14th Jan, 2011 rubicon said:
please dont put a batty kit on it, il have to by internet law, Report you to barry boys.com |
14th Jan, 2011 at 08:26:14am
I managed to fit mine with the engine in, like minx says, the pulley is a bastard, but not impossible. The rad needs to be out and you'll need the right hand engine mount off and the engine jacked up slightly on that side. I had to modify that engine mount slightly so got clearance on the pulley.
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
14th Jan, 2011 at 11:47:38am
as above.. jack engine on one side after you take the engine mount of to put the pulley on.
14th Jan, 2011 at 02:13:39pm
Same Idea with the fan pully- will I need a puller as that too?
Edited by jeffreypang911 on 14th Jan, 2011. |
14th Jan, 2011 at 02:24:16pm
leave the engine in gear, and have someone sit on the brakes.
15th Jan, 2011 at 11:44:49am
i used a screw driver & took the starter out to lock up the ring gear on the starter.
15th Jan, 2011 at 08:45:46pm
did all mine with the engine in. found it easy. just jack the engine on that side after removing the engine mount bolts. Got to be easier and faster than pulling the engine out... I run a supercharger and I don't care the TB is on the wrong side.
16th Jan, 2011 at 05:06:09am
yep did it the same was as you graham :) easy. |
869 Posts Member #: 2443 Post Whore Cheshire |
27th Jan, 2011 at 09:21:16pm
Its easier on an MPI as you dont need to swap the crank pulley! |
