Home > Help Needed / General Tech Chat > pressure ragulator piping
nogin
Member #: 487
westbury, wiltshire
does it matter if you take the pipe for the pressure regulator off the plenum chamber or the turbo wouldnt of thought so but i dont know thats why im asking cheers
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
minimark
Member #: 19
newcastle
never thought of doing it that way ....but if you have a bleed valve set up , don`t think you get a true reading and the off take is already on the plenum away to go to the fuel reg.
why would you want to make things hard for yourself
plenum!
like mark says dont make life hard for your self
if you take the hose of the turbo exit pipe
its possible to get heat creep up the pipe to the diaphram on the reg and duff it!
nogin
Member #: 487
westbury, wiltshire
ah well i wil not do that then i asked becuase i am using the plenum one for my boost pressure guage, will have to make another exit for the pressure regulator
i also make things
boost gauge wants to be off the manifold ideally. reads the pressure the engine is seeing then.
nogin
Member #: 487
westbury, wiltshire
well of the manifold it will be then,
i also make things
Disk full (/tmp/#sql_c9d4b_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
