| Home > Wanted > Good rear subframe and brake compensator valve | |||||||
14th Jan, 2011 at 04:41:20pm
Any one near me got a good rear subframe? Built up or not..
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
14th Jan, 2011 at 05:36:01pm
On 14th Jan, 2011 almichie said:
Also after a good compensator/bias brake valve, the one that bolts to the bulk head Al. The standard rear subframe mounted valve is dead easy to convert from non adjustable to adjustable. It's what I've got fitted on the beam supplying the rear discs on the van and it saved me about £70.
I can show you at Bingley. Richard. Minivanless, but reluctantly happy living with the decision. There'll be another one day.
14th Jan, 2011 at 06:42:39pm
Not the one of the rear subframe, I need a rear subframe!
14th Jan, 2011 at 06:50:55pm
I have a few valves from the bulkhead, but I've never tried any of them so can't guarantee them.
83 Posts Member #: 889 Advanced Member warlingham jct6 m25 nr gatwick |
21st Jan, 2011 at 09:34:42pm
got a rear subframe £100 its used gen not rusty, can get to to bath if that helps cant fix it F:(k it |
25th Jan, 2011 at 12:11:05pm
Al.
25th Jan, 2011 at 01:54:47pm
i have an 'as new' compensator valve - make me an offer if your still after one. |
25th Jan, 2011 at 03:13:22pm
25th Jan, 2011 at 03:14:17pm
Minidave - I'll let you know in a week or so On 7th Nov, 2011 apbellamy said:
