| Home > Technical Chat > Hard anodizing | ||||||
![]() 334 Posts Member #: 6647 Avon Park Class B winner 2010/11 milton keynes |
14th Jan, 2011 at 08:18:36pm
Can anyone help with a description on what the difference is between hard anodizing and normal anodizing??
14th Jan, 2011 at 08:27:43pm
IIRC hard anodising is the same except they use a higher voltage to get a thicker coating, up to about 50v for normal annodising and auto a couple of hiundred volts for hard annodising,
14th Jan, 2011 at 08:35:41pm
So it's just a case of a coating? so the only reason for hard anodising is to make it harder to scratch?? is that right? |
14th Jan, 2011 at 08:49:19pm
thats my understanding yes,
14th Jan, 2011 at 09:07:40pm
joe, is it you with the diy anodising setup? seem to remember someone has built one a while back, me and my dad want to dabble in doing some stuff Yes i moved to the darkside |
14th Jan, 2011 at 09:12:19pm
nope not me,
14th Jan, 2011 at 10:29:59pm
Hard anodise is fucking HARD!! you know its hard when you are using a HSS drill bit and you get sparks!!!
Edited by Sprocket on 14th Jan, 2011. On 26th Oct, 2004 TurboDave16v said:
14th Jan, 2011 at 10:57:57pm
Cheers guys that helps alot |
