| Home > For Sale > Sold - MG Metro Cam | |||||||
16th Jan, 2011 at 01:31:35pm
Lucky find in a block I have just stripped. Suspect this came from either a Metro GTA or RSP Cooper. Clearly identified with the 1/4" groove between lobes 1 and 2 and double checked with lobe lift at 0.263". Very good condition. £40 plus postage.
Edited by Sprocket on 29th Jan, 2011. On 26th Oct, 2004 TurboDave16v said:
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
16th Jan, 2011 at 04:47:56pm
sorry for the highjack...
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
16th Jan, 2011 at 11:19:50pm
On 16th Jan, 2011 rubicon said:
sorry for the highjack... Colin i have a few 1275 cams some stamped, but in with them is a Bill richards turbo cam, one that he ''did'' for someone a while ago, what do i need to find out whats what?? cheers!! If your BR cam is mixed in with a bunch of standard ones, the only way to identify it is to identify the standard cams and measure the lobe lift. I'm not so sure the lobe base circle diameter was the same through the ages for it to be a good enough way to identify a regrind. You could look at the cams and see if the lobes and base circle diamters look smaller on one cam, which might then the the regrind. Check out the link on how to identify the most common standard cams http://www.mlmotorsport.com/forum/index.php?topic=11.0 On 26th Oct, 2004 TurboDave16v said:
17th Jan, 2011 at 12:57:11am
24th Jan, 2011 at 10:26:19am
BUMP
29th Jan, 2011 at 12:39:11pm
162 Posts Member #: 9342 Advanced Member Southern Norway. |
1st Mar, 2011 at 12:29:35am
crap, i think i missed it :p |
