Home > Help Needed / General Tech Chat > Rotor arm issues
jackrabbit
Member #: 9034
Ok my previous topic won't start/backfires. I may have a clue I've put this rotor arm on it's from a local motor shop however I now believe it's wrong http://www.minispares.com/Product.aspx?ty=...id=37135&title=
Do you know which arm I need?
Would this cause backfire and it not to start?
You claim you have a spark at each plug. So clearly the rotor arm is working.
But it is appearing everything didnt go back exactly as it came apart......as you've changed this at least.
jackrabbit
Member #: 9034
Everything went back but I replaced the cap and arm for good measure! I read onthe minispares website this arm is for all electronic dizzys except turbos wasn't sure if perhaps it sits in the wrong position
Turbo_Jonesy
Member #: 9041
Why don't you ty fitting the old cap and rotor arm then see if it helps.
jackrabbit
Member #: 9034
Don't have the old rotor! Does anybody have a number for the correct rotor arm !
whats the part number on the dizzy?
But again...you have already said you have a spark at each plug....even though you dont have a clue if the spark is at the right time.
So do you have spark or dont you ?
Turbo_Jonesy
Member #: 9041
I think this may be a loosing battle guys..
jackrabbit
Member #: 9034
Ok so it must be working as I'm getting a spark the leads ate correct order so I presume there firing right I will try new leafs and plugs!
jackrabbit
Member #: 9034
Sorry predictive text!
If you're getting a spark then you dont need plugs and leads either.
What is the problem you're having?
jackrabbit
Member #: 9034
It turns over great but just won't fire it backfires through the exhaust!!
100ev8
Member #: 9138
wolves
have you got a pic of the dizzy with the leads in place ?
http://www.fishfight.net/
then the timing is wrong,
picture = 1000 words.
I'm beginning to think there's an echo in here
Ok...
Do this...
Take number one spark plug out.
put a finger over the spark plug hole.
turn the engine over by hand until you feel air pressure against your finger.
put a screwdriver down the plug hole and keep turning the engine by hand until you feel the piston come to the top.
remove the distributor cap and look to see where the rotor arm is pointing to.
put no1 lead on the socket that the rotor arm points to
put no4 lead on the opposite one to no 1
put no3 lead on the next one anti clockwise form no1.
start it up.
how do you know it is an echo if you dont listen to the first one?
On 18th Jan, 2011 Joe C said:
Ok...
Do this...
start it up.
Probably best to put number 2 lead on the last remaing free connetor too...
try putting plug lead no 1 in your mouth, and no 2 down our trousers then cranking it over *tongue*
Best advice ever! *Rofl!*
