| Home > General Chat > Water temp oil temp | |||||||
![]() 902 Posts Member #: 111 Post Whore Loughborough |
18th Jan, 2011 at 08:47:45pm
Is there a difference between a water temp gauge and a oil temp gauge? Or is it just the picture on the gauge face? |
18th Jan, 2011 at 08:56:44pm
oil gets hotter?
Yes i moved to the darkside |
18th Jan, 2011 at 08:59:50pm
well the gauge i have goes from 35 to 110 if the oil gets that hot i know i need the oil cooler, if it doesn't i'm fine.
18th Jan, 2011 at 09:51:02pm
On 18th Jan, 2011 Alex1340 said:
well the gauge i have goes from 35 to 110 if the oil gets that hot i know i need the oil cooler, if it doesn't i'm fine. I can't find a smith oil temp at the moment. http://www.demon-tweeks.co.uk/Motorsport/G...Gauge/1771/6599 http://www.demon-tweeks.co.uk/Motorsport/G...e/1771/0/141793 Edited by stevieturbo on 18th Jan, 2011. 9.85 @ 145mph
19th Jan, 2011 at 04:00:41pm
the optimum oil and water temp for max power is oil 100c and water 74c
19th Jan, 2011 at 08:06:53pm
The main question is.... If I connect this gauge will it read accurately? |
![]() 514 Posts Member #: 5362 Post Whore wexford in ireland |
19th Jan, 2011 at 10:42:40pm
i put water to an oil temp gauge and my running temp was 120 degrees, On 5th Jan, 2011 wolfie said:
he floated over to mine for a bit of ring |
19th Jan, 2011 at 11:25:46pm
On 19th Jan, 2011 Alex1340 said:
The main question is.... If I connect this gauge will it read accurately? Which gauge ? Temperature is temperature. Shouldnt matter what sticker is on the gauge face. Only thing that will matter is quality of the gauge workings, and the sender unit accuracy etc. 9.85 @ 145mph
