| Home > Technical Chat > Engine Simulation Software | |||||||
19th Jan, 2011 at 02:46:32pm
I've been playing with some very interesting software.
19th Jan, 2011 at 02:53:07pm
so im guessing with this, you could change cam specs etc and see how it effects the charge robbing and maybe find away to reduce/overcome it? |
19th Jan, 2011 at 03:05:57pm
Why is the exhaust pressure dropping so much with both valves closed in the centre port compared to the outer ones?
Edited by wil_h on 19th Jan, 2011. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
19th Jan, 2011 at 03:31:48pm
The centre siamese port together with the short length of manifold runner to the turbo causes a shock wave on this particular engine.
19th Jan, 2011 at 03:37:45pm
I wish my brain wasn't so feeble! If something is worth doing, it's worth doing half of. |
19th Jan, 2011 at 03:46:02pm
So, how does you current 'in-progress' manifold fair?
19th Jan, 2011 at 03:59:30pm
The above is for the in-progress manifold. I got the highest hp figures with the turbo in front of the grill! I've had to compromise a little by placing the turbo by the head, but I can see gains at around 4k to 6k. Peak was at 7.5k, now it is at 7k.
Edited by Paul S on 19th Jan, 2011. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
25th Jan, 2011 at 02:11:48pm
Interesting comparsion of VE on the inner and outer cylinders after optimising the inlet and exhaust manifold runner length on the 1293 with the Pierce head, GT2056, Ph2 ish cam etc.
25th Jan, 2011 at 03:10:35pm
that graph looks very similar to a graph about manifold lengths i was reading last night... On 28th Aug, 2011 Kean said:
25th Jan, 2011 at 05:05:40pm
What about a twin scroll turbine housing and use it to separate the exhaust manifold tubes ?
25th Jan, 2011 at 06:16:23pm
to elaborate on my comment above,
25th Jan, 2011 at 06:42:41pm
Thats very interesting.
25th Jan, 2011 at 09:18:35pm
Sooo,
26th Jan, 2011 at 09:36:08am
Improve a little at the bottom end but dropped away drastically at the top.
26th Jan, 2011 at 10:27:06am
I with you on this one.
On 19th Jan, 2011 John said:
I wish my brain wasn't so feeble! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
26th Jan, 2011 at 11:30:07am
Would anyone like to know the difference in average exhaust gas temperature on the outer and centre ports on a simulated high spec NA 5 port engine?
26th Jan, 2011 at 11:35:04am
Go on then. I kind of understand what you are illustrating, so it would certainly be interesting. I think it's only contentious to you though... On 11th Feb, 2015 robert said:
26th Jan, 2011 at 11:54:53am
Go on then Paul. If something is worth doing, it's worth doing half of. |
26th Jan, 2011 at 12:51:06pm
That's very interesting!!!
26th Jan, 2011 at 12:57:21pm
120 deg c On 28th Aug, 2011 Kean said:
26th Jan, 2011 at 01:05:12pm
Joe, that's close.
Edited by Paul S on 26th Jan, 2011. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
26th Jan, 2011 at 01:24:56pm
It seems that once you know the difference in temps between the exhaust ports for a known configuration they track by a similar amount for the same chamnge in AFR. On 28th Aug, 2011 Kean said:
26th Jan, 2011 at 01:53:28pm
the centre exhaust runner is 129 deg c hotter than the outers? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
26th Jan, 2011 at 02:04:08pm
On 26th Jan, 2011 wil_h said:
the centre exhaust runner is 129 deg c hotter than the outers? The average gas temperature through a 720 degree cycle is 129.6 Deg C hotter on the inner port than the outer. It is because there are two pulses every cycle on the siamese port as opossed to one on the outers. If you are measuring with a thermocouple, you will just pick up the average. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
26th Jan, 2011 at 02:12:16pm
I need to get my head round this and how the thermocouple would work in practice. Frequency response of the probe etc.
