Home > General Chat > Tube bending help
Gavin Wakely
Member #: 793
Hi
I'm trying to get some pipe bent, but struggling, The tube is T45 32mm Dia 1.6 wall thickness, and the radius required is 12" x 180 Deg (half a circle), and I require 2 off. I already have the tube. I've spoken to several quality fabies and the issues appear to be the long radius aswell as correct tooling required and the material spec of T45 can split if not done correctly ?
Any info would be greatly apprieciated.
Cheer's Gavin
Gav, forget fabrication shops, .you need a specialist tube manipulater type firm, look up "ring rollers " in you local area
carl
carl
Be careful, you may get more than you bargained for ! Lol
blister
Member #: 2590
Croydon
not to thread hijack but thought not worth opening a new thread *happy*
anyway i am after bending some mild steel that is 20mm diameter with a 1.8-2mm wall,
would hydrolic be over kill or not? or possibly a 32mm plumbers pipe bender or will this leave me with kinks!
SidewaysGTM
Member #: 5022
Oxford, Kings Lynn, Pod, Pub.
Gav
Hauser or webster race cars would be worth a call im sure one of them is not too far from milk and beans talk to stuart
Neil
Edited by SidewaysGTM on 20th Jan, 2011.
Got A GTM With A Honda In the Back, and huge Nitrous bottle where the passenger seat should be when racing!
On 19th Oct, 2009 Nic said:
Ill donate to the cause if you can make it do wheelies!!
imaginearat
Member #: 9008
Lancashire
Hi, I can bend up to 90 degrees in 42 x 3mm CDS ( drag racing spec ) if that's any use to you.
a local lad knocked up his own copy of a z-car, he bend all this pipes himself, (iirc they were t45 too)
i think he said he filled them with sand, got them warm, and just bend them round a wooden form
dont take my word for it though
Kean
Member #: 341
aka T2clubby
South Staffs
You need yourself and electricians conduit bender mate, you can hire them from hss or maybe a friendly spark.
