| Home > Help Needed / General Tech Chat > mini-metro parts share | |||||||
173 Posts Member #: 9184 Advanced Member lancashire bolton |
20th Jan, 2011 at 09:14:01pm
Evening all.
20th Jan, 2011 at 09:18:59pm
non really. On 11th Feb, 2015 robert said:
20th Jan, 2011 at 09:23:36pm
someone correct me if im wrong, but the only parts ive noticed are;
20th Jan, 2011 at 09:33:50pm
Gearstick. If something is worth doing, it's worth doing half of. |
20th Jan, 2011 at 09:43:23pm
Not much then lol |
1050 Posts Member #: 764 Post Whore Staffordshire |
20th Jan, 2011 at 11:27:42pm
brakes can be swaped too
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
20th Jan, 2011 at 11:54:04pm
sun roof?
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
21st Jan, 2011 at 06:42:36am
For the mini believe minispares do them and for the metro mgw-racing- could be wrong thou. |
21st Jan, 2011 at 08:16:52am
rear hubs are the same, but they're not suspension On 11th Feb, 2015 robert said:
21st Jan, 2011 at 10:49:25am
I used mini rears on mine many years ago - made a huge differance
On 20th Jan, 2011 rubicon said:
sun roof? whilst were on the subject, where to get some spax for the front of my turbo? |
21st Jan, 2011 at 10:56:11am
They are shorter, so unless you are signifcantly lowered you will have problems with travel. They also aren't designed to carry the weight of the engine, subframe etc etc On 11th Feb, 2015 robert said:
203 Posts Member #: 1734 Senior Member Lancaster |
21st Jan, 2011 at 10:56:14am
front subframe upper arm pins are the same. |
21st Jan, 2011 at 10:58:46am
sun roof? whilst were on the subject, where to get some spax for the front of my turbo? not spax but AVO do shocks for the Midas Gold....which are same as the metro fronts. |
21st Jan, 2011 at 11:43:38am
i just thought about sticking a pair of rear mini coilovers on......? On 2nd Oct, 2009 Vegard said:
21st Jan, 2011 at 11:45:13am
On 21st Jan, 2011 rubicon said:
i just thought about sticking a pair of rear mini coilovers on......? On 11th Feb, 2015 robert said:
21st Jan, 2011 at 01:37:00pm
clearance from base of rear subframe to ground was circa 50mm - it was low!
On 21st Jan, 2011 apbellamy said:
They are shorter, so unless you are signifcantly lowered you will have problems with travel. They also aren't designed to carry the weight of the engine, subframe etc etc |
