Home > General Chat > concealing wiring loom
After stripping out the redundant stuff and integrating the megajolt wiring into the loom, I'm now thinking about running it all internally, moving the fuse box inside the car as well to clean up the bulkhead and engine bay area.
Anyone else done this using a standard loom as a basis? I'm thinking of bringing the loom out in the inner wing with a suitable boot and running it down under the brace bar to the front panel and simply pop the cables through grommets for the wiper motor.
am I just making more work for myself or is it worth doing for the appearance??
I've done this with a steel front. Just extended everything by about 6 inches and run the loom through the hole left by the fresh air vent with a grommet. Everything is hidden in the wing.
I've no inner wings so there will be something visible but i can live with that.
Kean
Member #: 341
aka T2clubby
South Staffs
Did it on mine mate, definitely worth it, makes for a much more presentable engine bay.
I have done it in my car mate. but i have been thinking i can get it looking better lots of work but lol.
I'll go down tomorrow night and give it some thought then. I want to do it in such a way i can still remove it in one piece
Kean
Member #: 341
aka T2clubby
South Staffs
This image just about shows where the loom appears for the edis.
This is where i put all my sutff mate and all the jolt bits to.
rosco454
Member #: 5222
Northumberland
Kean that is really tidy,great job!
Im trying to come up with a way to hide the wiring without inners wings but its not the easiest of tasks.
Cheers Ross.
Kean - thats exactly what I'm looking for.
I thought about mounting the EDIS inside but given it is supposed to have a heatsink I thought it would be best where it is (same as Keans). I've drilled the holes now anyway so I suppose I'm commited now
I plan to conseal mine.
If you have no inner wings, you could run the wiring through the side of the subframe where the engine mount bolts go, then up your inner wing/arch area beyond the shhockers and through into the cabin.
I plan to do something similar so put some pic's up when you have done it so that I can steal your ideas *wink*
I'll keep you posted
