| Home > Help Needed / General Tech Chat > fuel regulator problem/, Maybe fuel pump?? 04/03/11 | |||||||
21st Jan, 2011 at 07:50:47pm
Hi all,
Edited by cossierick on 4th Mar, 2011. |
21st Jan, 2011 at 08:00:55pm
It can only be a few things
29th Jan, 2011 at 08:36:01pm
Right ive had a very shit afternoon.
30th Jan, 2011 at 10:17:02am
If your fuel pressue is higher than the needle valve can withstand then fuel will piss out of the anti-run-on valve vent, that's normal. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
30th Jan, 2011 at 10:25:35am
Rick do you want to borrow mine to fault find?
30th Jan, 2011 at 11:15:42am
Thanks neil but it wouldnt fit without a lot of messing .
31 Posts Member #: 9334 Member |
30th Jan, 2011 at 12:25:02pm
Maybe a duff float valve will drop the pressure in regulator to carb line enough to mess with the regulator setting? How about blocking that line to measure the pressure with no fuel going to the engine? |
30th Jan, 2011 at 07:20:12pm
what kind of regulator? ,most wont go low enough to supply a carb.. turbo 16v k-series 11.9@118.9 :)
30th Jan, 2011 at 07:26:52pm
Dennis its the propper rising rate from mini spares.
2nd Feb, 2011 at 07:41:02pm
Right its getting the better of me.
2nd Feb, 2011 at 08:49:23pm
s##t i will have to look at my one now before it gos on the car as its tapped out to. I have started posting on Instagram also my name on there is turbomk1golf
2nd Feb, 2011 at 09:59:36pm
love the paint job on your car.. looks good. I run a supercharger and I don't care the TB is on the wrong side.
2nd Feb, 2011 at 10:11:30pm
That doesnt make sense.
2nd Feb, 2011 at 10:15:49pm
Well you can't change the diaphram. So the only way is to block it up again and re drill it smaller I guess. Not sure 100% on exactly how. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
2nd Feb, 2011 at 10:28:45pm
Sorry gents im not explaing it very wel.
3rd Feb, 2011 at 07:42:28am
It's dead simple. As the boost rises it blocks the return. As less fuel is allowd to return, the the pressure to the carb increases.
3rd Feb, 2011 at 02:13:53pm
There is no way with an efi pump it would ever fully close.
3rd Feb, 2011 at 07:25:58pm
Its broke the gauge so waiting for a new one. I dont fancy getting another new one so il have a mess and see what i can sort.
196 Posts Member #: 2301 Advanced Member Blackpool , Lancashire |
5th Feb, 2011 at 02:43:11pm
I had a the same problem . the fuel pipes I was using were too big.
http://s256.photobucket.com/albums/hh167/boz-reb-2303/
5th Feb, 2011 at 04:40:00pm
On 5th Feb, 2011 boz-reb-2303 said:
I had a the same problem . the fuel pipes I was using were too big. Darren ? 9.85 @ 145mph
5th Feb, 2011 at 06:38:56pm
Sorry for not explaining myself , I first used copper pipe that was 10mm external and 8mm internal. Thats when I was having problems with the high fuel pressure.
5th Feb, 2011 at 06:59:55pm
Sorry for not explaining myself , I first used copper pipe that was 10mm external and 8mm internal. Thats when I was having problems with the high fuel pressure. I changed it to another copper pipe that was 6mm external and 4.5mm. that brought the pressure down. Darren Whilst it may have brought the pressure down. It was just a band aid to another actual problem. Whether 8 or 10mm lines, these Malpassi regulators should have no problems giving a usable fuel pressure for a carburettor. They are used on many turbocharged cars, Metro, Maestro, R5, Lotus Esprit etc They do what they are supposed to do. You must have had a very poor return line back to the tank or something. 9.85 @ 145mph
4th Mar, 2011 at 05:35:17pm
Right gents ,im getting nowhere with this.
4th Mar, 2011 at 05:59:12pm
what pump you running rick?
4th Mar, 2011 at 06:15:52pm
I will check exactly but im sure this is wot i orderd, its that long ago now.lol
