| Home > Help Needed / General Tech Chat > gear ratio | ||||||
![]() 281 Posts Member #: 441 Senior Member |
10th Mar, 2005 at 03:53:34pm
anybody running this ratio on a turbo with standard diff? Edited by 1275_dan on 10th Mar, 2005. |
10th Mar, 2005 at 04:08:33pm
A+ Standard
10th Mar, 2005 at 08:30:52pm
Im running the minispares clubman gearset which has pretty much the same ratios as the ST set. Im using a 3.2 diff and 10" wheels. -MINI CLUBMAN 1380 TURBO- |
10th Mar, 2005 at 10:51:59pm
does yours seem hesitant getting off the mark? |
11th Mar, 2005 at 08:41:42am
On 10/03/2005 22:51:59 1275_dan said:
does yours seem hesitant getting off the mark? Do you mean if his better half is hesitant to get off Mark?? Mark, do you know something we don't?? On 13th Jul, 2012 Ben H said:
11th Mar, 2005 at 10:18:28am
I'm using 2.3 1st with 3.44 diff, on 10's no problems On 15th May, 2009 TurboDave said:
11th Mar, 2005 at 04:50:42pm
On 10/03/2005 15:53:34 1275_dan said:
anybody running this ratio on a turbo with standard diff? part number CSTN77 (special tuning) 1st Gear 2.544 2nd Gear 1.731 3rd Gear 1.258 4th Gear 1.0 I'm running these ratios on my 1450 nonturbo with 3.44 diff and 13's. first gear is LONG but the rest seem well spaced. my clutch takes a hammering driving in traffic though. Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
11th Mar, 2005 at 05:15:01pm
yeah i find its like pulling away in second some times,but when changing gear the revs dont drop as much as they used to. you find that?? |
11th Mar, 2005 at 05:27:45pm
i sure do.. but when you get it going it shifts through the gears like a banchee. I have the added bonus of 5th so it still makes motorways easy driving.
![]() 2641 Posts Member #: 19 Post Whore newcastle |
11th Mar, 2005 at 05:58:40pm
vegard ....... i know nothing !!!!
11th Mar, 2005 at 06:03:19pm
2.54 first is easy with any turbo engine. If it isn't easy, your engine isn't powerfull enough! On 17th Nov, 2014 Tom Fenton said:
11th Mar, 2005 at 06:42:47pm
I find my 1st gear ideal, the std a+ i had before was way too low geared in 1st, also can do a 0-60 run with 1 gear change (just). -MINI CLUBMAN 1380 TURBO- |
11th Mar, 2005 at 07:11:23pm
On 11/03/2005 18:03:19 TurboDave said:
2.54 first is easy with any turbo engine. If it isn't easy, your engine isn't powerfull enough! TurboDave comes out with a cracking one liner. But I must agree, with a low compression engine and a long duration cam 2.54 would feel smooth as there isn't enough grunt off boost to pull the skin off a rise pudding :) now add some right foot and a gauge full of PSI's, Dump or Slip the clutch it's your choice and off she goes at warp speed if it all holds together. I guess I was giving my none turbo opinion of running 11.5:1 with a 286, Weber, grey dia and rally plate makes for a very cammy not liking first gear combination but having said that I?ve put up with it for many years now and intend to for many more. Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
12th Mar, 2005 at 09:06:29am
well mine is a 2.54 1st with a 2.9 on 13,s im in the milkfloat racing club!!!!.
