Home > Technical Chat > normally aspirated pistons
ips
Member #: 9321
wakefield, west yorkshire
right i'l start at the beggining i've bought is what i thought was a full complete standard turbo power plant. turns out the block is a normally aspirated engine with turbo etc. the question is is how long before i melt my pistons and is there owt that i can do to prevent it? i'm gonna be using a calibra intercooler and 1.5 forged rockers other than that standard setup.
i've tried the search tool to no joy any help would be great
cheers
depends what pistons, some are better than others, the blocks are the same
if you have to ask "how long before i melt my pistons" they you probably shouldn't be messing with it
ips
Member #: 9321
tbh the condition of the engine is pretty good. what i ment was if i dont do something about standard 6cc (or whatever it is) dish would this be enough to cope with just strapping a turbo on or would i have enlarge the chambers? what the min. size that would cope? i get most of it, its just that i should ave been more careful in the 1st place and that has caused me more work that i dont quite get
its the overall compression ration vs boost you need to be worried about, plus spark advance get the combo wrong hello dett good by engine 4spi boost and a goo intercooler and you 'may' be safe i realy dont know too many variables
ips
Member #: 9321
that still helps though, cheers
all depends on how messed with the engine is, how much boost is used, and how well set up the fueling and ignition are.
A normally aspirated 9.4:1CR A series engine used a 7cc piston with a deck hight of roughy 0.040", while the Turbo 9.4:1CR A series engine used a 12cc piston and almost zero deck hight.
If its standard compression ratio, you will be limited as to what boost you run. if you try and push the boundaries of boost with a standard 9.4:1CR, you then might damage your engine, but it will unlikely be the fault of which ever pistons are in there, other than maybe if they are KING pistons.
ips
Member #: 9321
KING pistons i doubt. how would i go about lowering the deck height then? if i was to lower the deck height and and run aprox 4 or 5 psi of boost would this be enough?
Get the chambers in your head opened out, does the same job as opening the piston dish out, but doesn't involve stripping the whole engine down.
PM Benross, he's near to Wakefield and is very good with heads.
I fear you need to stop, and learn a little more about engines. start with how to calculate the compression ratio.
I say this because it is clear you have miss interpreted what I was talking about. Perhaps it was the way I wrote it. Just to clarify, lowering the deck hight with the same pistons installed, will INCREASE your compression ratio. This is BAD on a turbo motor. a Metro Turbo engine used a 12cc piston, with a zero deck hight, wich is exactly the same as a 7cc piston with a 0.040" deck hight.
The only other piece of advice for the time being is to calculate the compression ratio you have now, BEFORE you start thinking about doing any changes.
scott the joiner
Member #: 9229
newcastle upon tyne
I've got a set of turbo pistons if you fancy ya chances on doing a rebuild? *smiley*
ips
Member #: 9321
i get what your on about now you've said it again sprocket. i know you need lower compression to run a turbo than a n/a engine. i'm just tryin to weigh up all my options before i start. i've just had conflicting info before i joined on ere.
from what i can gather mr. benross is a very busy man cos my mate has being waitin 3months before he could fit him in.
cheers for all your advice its been very helpful
I think I can put it more simply.
Calculate the CR. if it is 9.4:1 or less run standard metro boost (7psi). If it is higher than 9.4:1, find a way to lower the CR.
The standard pistons will cope with 7psi boost assuming that ignition advance and fuelling o=is ok.
bennyy
Member #: 9037
Doncaster, yorkshire
Benross is a great bloke, drop him a pm, I'm only waiting 2-3 weeks for my head back :)
On 15th Mar, 2012 wil_h said:
Disk full (/tmp/#sql_c9d4b_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
